any good air drill with variable trigger? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2012, 06:40 PM
put up or shut up
I obviously wouldn't expect the trigger to be as touchy or strong as a powered drill but a few air drills are toted as having a variable trigger. This IR is said to have a variable trigger. Any thoughts? And yes I know air drills bog down when they're not fully throttled but I'd like to have one with just a tad of throttle touch.
opinions on air drills please.
http://www.ingersollrandproducts.com...px-am_en-32543
Old 02-25-2012, 06:43 PM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
inline air reg. at inlet, just like a paint gun.. you can set whatever speed you want.. with a turn of a knob
Old 02-25-2012, 07:16 PM
put up or shut up
yeah, I'd have that too but also would like some feel on the trigger. Mainly for my cobalt bits and spot cutter...basically everything I'd put into it. Thanks for the input.
Old 02-25-2012, 08:19 PM
All of My air drills have a variable trigger, They also have nuch more torque than electric drills. Like the previous poster mentioned, you can control the speed even more by using a regulator
Old 02-26-2012, 09:28 AM
put up or shut up
I don't think it's possible for them to have more torque due to being powered by air flowing through vanes, which means at the lower rpms it won't have the torque, where as a powered one would be more consistent throughout, but I'd like to think that the higher quality airdrills MAY be somewhat compareable to the powered ones. So which air drills do you have? do you have an IR one? On a side note, I would think that if more air drills had a lever instead of a trigger that also might help it trigger a little easier. You see those levers on the angled air drills but not normal drills but I have a feeling that could help as well.
Old 02-26-2012, 09:49 AM
Last journal entry: Finally some floor!
I've had IR's, both 1/4 & 3/8" for years and both are variable speed. Couldn't say how finite the control on the triggers are, never noticed. Love 'em though, and I've had many others including Snap-Ons & Mac's. The IR's always do whatever I need them to. Bob
Old 02-26-2012, 11:32 AM
put up or shut up
sweet, thanks for that. I read a review on line and someone said exactly what you said. I just had a HF one and it was basically stop or go, nothing inbetween. A few weeks after purchase it took 5 minutes just to get a bit out of it cause the bearings must have locked up or something. POS!
I'll get the IR, thanks!
Old 02-26-2012, 07:54 PM
I have Mac air drills, a small 1/4 inch, and a 1/2 inch. the small one turns 2000 rpm, & the 1/2 inch runs 700 rpm. I like the small one, It is handy due to its small size. It has as much torqu as a typical 1/4 inch electric drill
Old 02-27-2012, 12:15 AM
put up or shut up
never been let down by a mac tool. Love their air ratchets.
To Drill or Not To Drill Thermostat Sweet-34 Engine 21 01-08-2011 08:41 AM
what to use to trigger an electric fan? wave1957 Engine 13 09-14-2010 08:29 AM
Crank Trigger and Cam Sensor tomtruty Engine 6 02-09-2009 05:59 PM
To drill or not to drill steam hole in 400 Curtis Thornton Engine 9 06-27-2008 12:44 AM
To Drill or Not To Drill (Carb Question) leejoy Engine 40 03-04-2006 07:41 AM
