Any good "shorty" spark plugs besides Accel? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2008, 11:59 AM
I've been running the Accel shorty plugs on my 350 for the last couple of years for the extra boot clearance w/ headers. Are there any other good plugs out there that are close to the same size? I put on some Vortec heads and decided to get new plugs to go with. It seems the Accels I've had like to foul after a bit. I've been searching all over the net. A part number would be greatly appreciated!
Old 03-03-2008, 12:49 PM
Last journal entry: PICTURE TEST
plugs
Autolite AR series, they will out last the accel plugs 5 to 1. plus there 1/3 the price.
Keith
Old 03-04-2008, 06:10 AM
Would the AR racing series be fine with a motor thats 99% street driven? My compression is below 10:1.
Old 03-04-2008, 06:35 AM
plugs
the ngk plugs are just as short as the accel plugs and they dont foul as bad either and they are way way cheaper
Old 03-04-2008, 06:42 AM
406chevycaprice's Avatar
"CHEVY"THE ANTI-RICE!!!
yea i have got a set of storty plug's on my 406 sbc and i think they are junk .they do foul out to much of me .i was thinking about run some other plug's to .it coasted to much money($29.99 a set)to keep out changing them out all the time .yea if i was you i'd be running something els to
Old 03-04-2008, 07:32 AM
71 c-10's Avatar
just a kid and his truck
any one have a part number that would cross over to stock AC part number plug? I have use the accels and had them foul a bunch, getting ready to drop my new motor in and need plugs.
Old 03-04-2008, 10:00 AM
Jmark's Avatar
I checked the Autolite site for plug apps and came up empty on the "AR" series. The basic Chevy 5/8's plug is the Autolite number 26. Delco would be R45TS. Maybe someone else has a good cross reference.
Mark
Old 03-04-2008, 10:12 AM
plugs
Mark, they are a pain to find a cross for..
Type in autolite AR135 in a search engine and you will get a bunch of hits.
I only know the numbers that i have memorized..
Old 03-04-2008, 11:21 AM
Jmark's Avatar
Keith...no kidding! LOL I looked and looked and found nothing.
My son uses the Accel shorties and they don't last too long either. Guess it depends on the headers. I have Hookers and can run any OTC plug without problem. I think his are Headmans, which, in my opinion, suck even more then my "Heco in Mexico" Hookers.
About a year ago, I bought a full case (64) of Autolite Double platinum's on eBay for a buck each. Not real crazy about them now. I like the Autolite 26's or Delco's. I still have #2 pulling oil from somewhere and ashing up the plug about every 5 thousand. The plats just don't like oil for some reason.
Old 03-17-2008, 08:18 AM
PAS55's Avatar
short spark plugs
In my 350 I needed the short plugs to clear the headers, I used Champion RV92YC stock # 930 or NGK BR6FS stock #4323 these are the same length as the accel and are for a 350 marine application.
Garry
Old 03-17-2008, 08:30 AM
powerrodsmike's Avatar
Wiki Edits: 161
A while back I went to replace a set of the Champions you mentioned with a set of Accel shorties and yes they are the same short length, , and several dollars cheaper
Later, mikey
BE different....ACT normal.
Old 03-17-2008, 03:19 PM
http://www.sparkplugs.com/results_cr...CrossWarning=1
check this site out
Old 04-03-2008, 08:30 AM
spinn's Avatar
thanks
how interchandeable are element cores. is the electrode platinum white stuff as good as copper ?
Old 04-04-2008, 08:08 AM
Vortech 4.3's Avatar
jack of all trades
your fouling issues. is it possible that you have the wrong heat range ? causing them to foul.
Edelbrock heads / spark plugs ? driveability Engine 8 03-13-2006 07:29 PM
Spark Plugs on a 1999 grand prix rbfpezcore Engine 9 11-30-2005 09:37 AM
reading spark plugs abe Engine 8 01-12-2003 08:04 PM
spark plugs abe Engine 1 12-19-2002 03:47 PM
Good spark plugs?? jazzguitar Engine 6 11-18-2002 06:48 AM
