-   -   Any harm in installing and torquing rods one at a time? (http://www.hotrodders.com/forum/any-harm-installing-torquing-rods-one-time-226002.html)
loudandproud 11-12-2012 09:06 AM
I always have and havent had any issues... yet.
A more experianced builder was over at my house the other night and scolded me over it. He noted that i could be twisting the rod by not having it support by the other rod.
I never really gave it much thought until now.
From now on I plan on installing both rods and sticking a feeler gauge in between before torquing just for good measure.
But, have I been getting lucky all this time?
Any here guilty of this? Ever have any related problems?
MouseFink 11-12-2012 09:15 AM
Your advisor is correct. The normal practice is to install all the rod/piston assemblies before the torque procedure is began.
Not only have the rods on the crank with the rod bolts tightened to about 20 lb., but insert a .017" (or correct thickness) feeler gauge between the rods as you apply the final torque sequence to each pair of rod bolts. That will permit accurate and even torque to be applied to each of the rod bolts.
loudandproud 11-12-2012 09:21 AM
i have a set of rods i mocked up this way. How could I check them for damage before final assembly?
hcompton 11-12-2012 09:34 AM
Usally a sheet of thick glass from a coffee table is dead flat. You can lay the rods on it and check with a feeler guage for any deflection. A machiniist flat surface is much better but not cheap item to buy for a one time check.
They can be bent back but if you have never done it before machine shop usally doesnt charge to much to straighten and resize rods.
Stock cast rods are strong until they snap off. You can bend them but usally they dont bend that easy. But what it does do is flatten your rod bearings on one side since they are the weak link to side loads like that. They are only ment to support straight loads and that is at a rated oil pressure between them and the crank. Do use molly lube on the bearings and watch tp see if its pushed put after tq bolts. Also are you using a bolt stretch guage or tq wrench. Usally with tq wrench you have to repeat the process causing more stress on the bearings.
loudandproud 11-12-2012 09:58 AM
Damn. I will have to check the rod bearing. I hope i didnt jack this up.
327NUT 11-12-2012 10:18 AM
The chances of hurting anything is pretty damned remote, I'm assuming it's a small block chevy and that really doesn't matter, you're only going to 45 lbs.ft. or so anyway. In a perfect world the previous mentioned way is best but I wouldn't sweat it too much.
lmsport 11-12-2012 03:08 PM
You haven't done any damage.
I put all the rods in and only tighten with a speed handle then torque all 16 bolts in one setting. Makes the torque angle process less of a chore.
MouseFink 11-12-2012 03:34 PM
When you prepare rods for use, one of the things that need to be checked and corrected before further work is twist, even new rods! Stock rod bolts should be replaced with ARP bolts. ARP 3/8" rod bolts, when torqued in pairs to 45 lb. with ARP lube and a feeler gauge between the pair, will come up to torque quickly with 20 lb. initial torque then 45 lb. in one turn. Measured .005"-.007" bolt stretch.
loudandproud 11-13-2012 09:06 AM
.005-.007" is too high for these arps... they are 3/8th 8740. .0047.
Also... these rounds have been checked.
cobalt327 11-13-2012 10:57 AM
Having both rods on the journal doesn't mean the rod being torqued will be "leaning" on the adjacent rod unless the oil clearance was huge or the rod side clearance insufficient unless there are spacers (like feeler gauges) used between the adjacent rods.
There will be no twisting force applied to the rod during torquing.
Mr. P-Body 11-14-2012 12:21 PM
As a matter of practice, we wait until all cylinders are installed to "torque". Bringing each pair "up" for clear access, "whack" the pair back and forth a couple times with a "soft" hammer (tap the caps). We use a plastic one so no debris comes from the hammer itself. DO NOT use a brass hammer here. A rawhide hammer is okay. Insert that feeler blade (minimum .010", must be "hardened") on the side (between the rod and the crank, not between the two rods) that will get the pressure applied from the twisting of the wrench. This "centers up" the rods to each other, a critical point for bleeding oil and maintaining "straight".
Jim
