Any help identifying intake manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2005, 09:46 PM
Hey everyone I need a bit of help
We bought a 79 GMC heavy half this afternoon and so far we have managed to get the cylinder head numbers (462624) and the intake numbers (14007378) off of the engine. I have already identified the heads to be 75.5 cc 2.02/1.6 , but I'm having trouble locating any info on the intake. Not that it matters much about the intake but it may help me to get more info on the block and crank so I can know what I'm dealing with. Engine is still in the truck and way to greasy at the moment to be able to get the id number off of it.
Anyone can help me out with the intake, or possibly even have anything on the block with the numbers I have? Im assuming everything is as was original from the plant. Wish it hadnt gotten dark so soon...
Mike
Old 04-04-2005, 09:52 PM
kane583,
I would wait until you clean off the casting number because ANY intake can be put on the engine. Same for the heads for that matter. Let us know what you find.
Scholman
Old 04-04-2005, 11:12 PM
Will do
This whole intake deal is bugging me tho. This is a cast iron intake and I am sure of the numbers but all I can find says this intake casting number is aluminum.
Old 04-05-2005, 08:50 PM
Got the block casting number today (14016379) Everything seems to be ok other then the intake numbers. I still havent been able to figure out whats going on there. Did a compression check on all cylinders, 1, 3, & 7 are pumping up 135, 5 is 115 and 2,4,6,8 are all pumping 145. Plugs were well worn and showed no signs of oil, just a bit of gas on them but im sure thats from dumping gas down the carb to get it started. Looks like we are pulling the engine in the next couple weeks and changing the cam & lifters, etc and dropping it in a street stock so we can go roundy round
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
Intake Manifold won't fit Andrew7dg Engine 18 12-15-2008 08:27 AM
"Dry" Intake Manifold Question bluesman123 Engine 4 02-11-2004 12:12 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
intake manifold 69cougar Engine 2 12-29-2002 04:37 PM
