-   -   any idea?? casting # 3978044 sbc (http://www.hotrodders.com/forum/any-idea-casting-3978044-sbc-79457.html)
denny1977 01-21-2006 09:31 PM
please help 3978044 what year and cubic inches
Jmark 01-21-2006 11:38 PM
Are you sure about the number? It doesn't show up on any site i've looked at.
Bumpstick 01-22-2006 07:47 AM
I too cannot find anything on this number...? Are you sure its correct...? Can tell you the 397 series of blocks were early 70`s... Do a bore measurement (just lay a ruler across the center of the bore) and give a rough diameter which may help...?
DoubleVision 01-22-2006 08:07 AM
I`m guessing the number you mean is 3970014, the 8 is easily confused with 0, and 1 is easily confused with 4. So if your numbers are the above, you have a 350, used from 1970 to 1976, 2 or 4 bolt main cap. But this is just a shot in the dark.
