any idea?? casting # 3978044 sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2006, 08:31 PM
please help 3978044 what year and cubic inches
Old 01-21-2006, 10:38 PM
Jmark's Avatar
Are you sure about the number? It doesn't show up on any site i've looked at.
Old 01-22-2006, 06:47 AM
Bumpstick's Avatar
Hammer and a torch
I too cannot find anything on this number...? Are you sure its correct...? Can tell you the 397 series of blocks were early 70`s... Do a bore measurement (just lay a ruler across the center of the bore) and give a rough diameter which may help...?
Old 01-22-2006, 07:07 AM
DoubleVision's Avatar
I`m guessing the number you mean is 3970014, the 8 is easily confused with 0, and 1 is easily confused with 4. So if your numbers are the above, you have a 350, used from 1970 to 1976, 2 or 4 bolt main cap. But this is just a shot in the dark.
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
sbc heads shieldbreaker Engine 5 08-27-2005 08:12 PM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
SBC Block I.D. Casting# confusion 1Fast65Elky Engine 2 10-13-2004 07:44 PM
Trunk idea Wmarden Interior 13 11-07-2002 11:11 AM
