Any ideas - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2008, 03:22 PM
Giverhell and hopefer the best
Any ideas
The new motor i bought (350 four bolt) ant get primen to the pass side. Ive heard that the cam bearigs could be backwards. And since i didnt put it together i was wondern if it was the possible problem? And any other ideas would help. Thanks!
Old 01-31-2008, 03:28 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
The cam bearings wouldn't have much too do with oiling the top of the motor, if the bearings were backwards the oil would just go right by them. Either the lifter gallery is blocked or your pushrods aren't seated correctly, or you have an internal leak somewhere that you shouldn't. Or the lifters aren't picking up oil on that side or something.
Old 01-31-2008, 03:36 PM
DoubleVision's Avatar
If your using a hand held engine primer make sure its one that blocks the oil passage at the distributor, other wise one side wont get any. If you've started the engine and arent getting any after some time then theres the possibility a plug wasnt installed or has came out of a oil gally, but oil pressure would be otherwise very low if this is the case.
Thats kind of what i thought
That what i thought.So i pulled the push rod ands lifter agian and soaked the push rods in gas to make sure they r clean.And the lifters are still in the oil soakn. Im gon to put it back together tomrrow when i get off work.
Old 01-31-2008, 03:38 PM
Still out
The motors still out on a stand. And i made a primer at work.
Old 01-31-2008, 03:54 PM
When doing a prelube on the SBC, it is often necessary to wrench the crank over a few complete revolutions before oil will flow thru all the pushrods.
Bogie
Old 01-31-2008, 03:59 PM
thanks
Thanks but i tryed that.The only bad thing is im by my self when i was primen. So i had to stop then prime agian.
Old 01-31-2008, 04:10 PM
Is the intake manifold on? Without the intake, or the primer positioned as to how the distributor mounts to the complete engine, the right side lifter galley is open to the block and oil simply runs back to the pan, not only reducing total oil volume and pressure everywhere in the engine , but completely starves the right lifter galley of any oil.
Home made primer; I assuming is made from a Chevy distributor. There is a groove between two circular bosses toward the bottom, they close off the right side lifter galley, without this configuration, you've got a big leak back to the pan.
Bogie
Old 01-31-2008, 04:29 PM
Any ideas
Its made of an old oil pump shaft with a tall washer for lack of a better term. around the end.And the intake and valve covers r off.
Old 01-31-2008, 04:42 PM
Jmark's Avatar
The shaft and washer won't work. The oil feed passage goes AROUND the dist housing. With a straight shaft, the oil just dumps back into the block where the dist housing would be.
Lots of places sell a straight shaft primer for Chevies. Makes no sense to me! All you end up with is what YOU ended up with! LOL Half the engine getting primed.
You need to buy a REAL Chevy primer
OR modify an old distributor for it to work.
Mark
Old 01-31-2008, 04:54 PM
nissan's Avatar
Last journal entry: 1930 chevy ratrod pick-up
any ideas
I welded a lug nut on the top of an old striped down distributor an hook my air wrench to it.still works great after 30 years.
Old 01-31-2008, 05:49 PM
Any Ideas
Will any good auto parts store have a good primer? How much and will a chevy six cylinder distutor work?
Old 01-31-2008, 06:00 PM
Some V-6s will.
Trees
Old 01-31-2008, 06:41 PM
Any ideas
Well its out of a 4.3. Witch if i ant mistaken the motors r two cylinders shy of being the same thing.
Old 02-04-2008, 04:25 PM
any ideas
Hey i finally got my motor primed.The old dist worked great! Thanks fer all ur help guys! Now i have another problem.To tell the truth there were to many people helping me pull the old motor out.So now that im puting it back in theres no one around.So does any one have an idea on were the wries go after they leave the alternater?
I need ideas... BIGK Hotrodding Basics 6 10-02-2007 07:56 PM
paint ideas for four door 66 nova 2 merowe Body - Exterior 2 01-30-2006 12:47 AM
Garage ideas Kevin45 Garage - Tools 8 11-19-2003 05:40 AM
annivrsary ideas 38 special Hotrodders' Lounge 16 05-17-2003 11:07 AM
Hot rod family ideas??? Keith Boisvert Hotrodders' Lounge 12 09-08-2002 05:09 PM
