any ideas on increasing hood clearance? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2003, 08:34 PM
Last journal entry: New photos
Post any ideas on increasing hood clearance?
any ideas on increasing hood clearance without modifying the hood on a sbc? please be specific(type of manifold etc.)
thanks
Old 01-09-2003, 08:57 PM
banned
Post
HMM you could try setting up tubing.. that way you don't need an air cleaner on top (much like a fuel inject) thats about all I can come up with...
Are you sure you don't wanna build a big old scoop????/
Old 01-09-2003, 09:15 PM
Post
the edelbrock torquer 2 manifold had a very low plenum and summit and p.a.w have aircleaners that
are only an inch taller than the carb the air cleaner is shaped like a T off to both sides is a square air filter
Old 01-11-2003, 04:58 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
Off set air cleaners are 1 1/2" from center line.
You can rotate them for more room.
Luv the smell of NITRO in the morning.
Old 01-11-2003, 10:37 PM
New Member
Post
Ahh cut a big o'l hole in your hood and rumble around town!! LOL ok ok maby not! I have less 1.5 inches of room under my hood. My brother almost had to start chopping, but he put in a smaller air cleaner, and took out the padding under the hood. Have you considered adjusting your linkages ?? I am very interested to find out how your project works out! what size of carb spacer do you have ??
Old 01-14-2003, 12:56 PM
Post
Summit and Jegs both carry "drop base" filter assemblies. These will allow you to sue the same size filter, but the base drops down over the carb some.
Old 01-14-2003, 01:32 PM
deuce_454's Avatar
Post
half a pound of industrial dynamite, or a quarter pound semtex or C4, placed atop your engine and detonated with the hood closed and duct-taped in place should give all the clearence you need..
My other and less unrealistic advive would be the K&N filter nitro junkie mentiones, or the edelbrock pro-flo filter (triangular gizmo) they are both only about 1 inch taller than the carb.
[ January 14, 2003: Message edited by: deuce_454 ]</p>
Old 01-14-2003, 02:12 PM
banned
Post
WEll here is what I would do... take an air cleaner, cut the thing so that you have the part that sits on the carb... cut some sheet metal and weld sides and a top on it (air tight, probably easiest to make a rectangal), then cut a small piece of pipe and a hole for it and weld it into your box (could use to pipes if you need more airflow) then run your tubing (like the fuel injects have) down the side out of the way to an air filter at the end... if you do a nice job of it, it won't look that bad and if you make it good and airtight you won't ruin your engine running it in sand...
An advantage to doing this is that you can place the opening to the system pretty much anywhere you want, like in the front, or the bottom of the car so that it draws in cold air instead of air that would be sitting under the hood warming up...
Old 01-14-2003, 04:46 PM
rs's Avatar
rs rs is offline
Post
Side draft webbers are nice...
Old 01-14-2003, 06:03 PM
irocz8868's Avatar
Thumbs up
one thing you could do is find a throttle body air tube off of a chevy tahoe. where the tube connects to the throttle body is L shape for clearance. this setup can be modified for carb systems. at the end of the air tube you can angle it towards the front of the car and use a 88 camaro breather box. it t's off into 2 breathers and that could give you the option of using air induction. LET THAT ENGINE BREATH. lol.
[ January 14, 2003: Message edited by: irocz8868 ]</p>
