-   -   any imfo on this holley carb? (http://www.hotrodders.com/forum/any-imfo-holley-carb-116812.html)
1972bigblockchev 05-26-2007 01:06 PM
the numbers i seen are 3310-2 and 3166.the 3166 IS STAMPED UNDER THE 3310-2 NUMBER.want to know how big it is and get a round about year.its a 4 barrel i know that much.HOLLEY CARB.
65 Elco 05-26-2007 03:02 PM
It's a 750 cfm vacume secondary type 4160 carb. Not sure which years it was used in. You can find out more @ the following:
http://www.holley.com/
poncho62 05-26-2007 06:39 PM
3310 was not assigned to any specific year car.....or brand of car. It is an aftermarket item.
66GMC 05-26-2007 09:38 PM
Yup.
It's a "universal" carb ... one of a few that has the Ford A/T kick-down linkage.
It was offered as both a 4150 and a 4160 version, and either a manual or electric choke, depending on suffix (3310-x) if I recall correctly.
tosten 05-14-2012 07:34 PM
3310 holley
I had a stock 71 Z28 and it came with a 3310. 780 vacuum secondary.. It is a good carb.
