any imfo on this holley carb? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2007, 01:06 PM
the numbers i seen are 3310-2 and 3166.the 3166 IS STAMPED UNDER THE 3310-2 NUMBER.want to know how big it is and get a round about year.its a 4 barrel i know that much.HOLLEY CARB.
Old 05-26-2007, 03:02 PM
65 Elco's Avatar
Last journal entry: Getting it done
It's a 750 cfm vacume secondary type 4160 carb. Not sure which years it was used in. You can find out more @ the following:
http://www.holley.com/
Old 05-26-2007, 06:39 PM
poncho62's Avatar
Wiki Edits: 5
3310 was not assigned to any specific year car.....or brand of car. It is an aftermarket item.
Ontario Rodders
Old 05-26-2007, 09:38 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
Yup.
It's a "universal" carb ... one of a few that has the Ford A/T kick-down linkage.
It was offered as both a 4150 and a 4160 version, and either a manual or electric choke, depending on suffix (3310-x) if I recall correctly.
Old 05-14-2012, 07:34 PM
3310 holley
I had a stock 71 Z28 and it came with a 3310. 780 vacuum secondary.. It is a good carb.
Holley Carb Gas Leak 64Joker Engine 21 07-18-2010 02:28 PM
Demon or Holley Carb for 306 Ford? Dino Boreanaz Engine 10 12-09-2006 06:04 PM
What holley 750cfm carb to go with ??? FiefSS Hotrodding Basics 17 09-29-2003 03:58 PM
Holley Carb Tuning Coleman396 Engine 4 07-19-2003 10:03 AM
Holley carb experts? Others? Why is my truck's fuel bowl being sucked dry? MuscleTruck Engine 5 05-23-2003 12:36 AM
