-   -   any info on installing northstar eng, into anything otherthan caddys.please help (http://www.hotrodders.com/forum/any-info-installing-northstar-eng-into-anything-otherthan-caddys-please-2039.html)
ralphcrogersjr 11-12-2001 07:42 PM
i saw a northstar installed in a hotrod on t.v.i am looking for any info regarding this subbject.thank you for your help and support
NEED INFO BAD :confused: :confused:
timstoys38 11-14-2001 02:49 PM
there is a northstar fiero in minnisota.
It is a mid engine install evrything is the same under the hood sorta-speak, just behind the driver. Real easy to do! surprised I didnt think of it first though.
there is Another one in portland OR but that one is more conventional, using the entire northstar cradle and all bolting that up to a re-designed frame and front end.
customized,chopped and lowered 49 cadillac.
there's a couple for ya.
kosmosive 11-15-2001 07:39 AM
Is there any reason you have chosen the northstar cadilac engine?
Just curious. mkosmal1@tampabay.rr.com
Pete Dow 11-21-2006 08:19 PM
northstar
if you can pshysically fit it in were it needs to go,fabricating mounts and so on,try electromotive for a wiring harness,laptop adjustable,stand alone management system,approx.12-1500.00,bosch frame mount fuel pump that can goto 90 psi,any 60 degree gm belhousing trans will work,although,man.trans flywheel was never made for northstar,any other questions please email.
jimfulco 11-21-2006 09:09 PM
http://www.hotrod.com/techarticles/e...engine_fitment is a magazine article
www.chrfab.com is the company site
Footstomper 11-28-2006 03:33 PM
cadillac motors rule!
I have several friends who have installed the northstar, it is a complex swap unless you use all the components from the donor car. I have a question about cadillac engine swap too. Not to break the thread, I am new on this website and do not know my manners yet.
I am upset with my chevy 305, it is in my 40 ford coupe. I considered the northstar, but I have found a 1975 cadillac 500. I can get plenty more smooth power than the souped up jerking little small block. I wonder if anyone can tell me what I am getting into this kind of swap? I have a early truck hydraulic slave cylinder with a 3 speed overdrive and a 9" with 3.7. I can get a flywheel and adapter from Cad 500. Other friends say it will not hold together, that I need to use the turbo 400. Also, I am wondering if I should replace my I beam axle for the bolt on Chassis Eng. MII? About the northstar, if you need some specific information, I will gladly contact people who have done it here locally.
Cstraub 11-28-2006 03:37 PM
What about an LS1 ? An all alumium engine they are right around 400#'s.
solidaxel 11-28-2006 03:37 PM
[QUOTE=ralphcrogersjr]i saw a northstar installed in a hotrod on t.v.i am looking for any info regarding this subbject.thank you for your help and support
NEED INFO BAD :confused: :confused:[/QUOTE
]For a complete set up go to Turnkey.com or Redline, my son had one in his sandrail, worked great but his new one with the LS-1 works even better!!!
