Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - any info on installing northstar eng, into anything otherthan caddys.please help
Old 11-21-2006, 08:19 PM
Pete Dow Pete Dow is offline
if you can pshysically fit it in were it needs to go,fabricating mounts and so on,try electromotive for a wiring harness,laptop adjustable,stand alone management system,approx.12-1500.00,bosch frame mount fuel pump that can goto 90 psi,any 60 degree gm belhousing trans will work,although,man.trans flywheel was never made for northstar,any other questions please email.
