Any info on my 350 Chevy Engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2010, 07:20 PM
I just picked up this Chevy 350 for my 1929 Dodge Sedan Hot rod. I am trying to find out some info on my engine. Like Possible Year, Original vehical used in, what I can do with it and if it is worth doing anything to. I took a few numbers off the block. Can anyone tell me any info on it. The casting numers are 3970010 and there are also other numbers.. 010, 02, 154. Not sure what they mean or what they can tell me. The person I purchased this engine from told me that it is pushin 450 HP. He said it is a 4 bolt Main with Titanium Bolts, Steel Crank, Ported and Polished 202-20-77 Heads angle shaved to 0.50. Silver Deep Dish Pistons, Titanium Push Rods, I-Beam Connecting Rods. Edelbrock RV Hard Cam, Edelbrock Roller Rockers, Edelbrock HP Oil Pump, Edelbrock Double Roller Timing Chain to match Cam, and a set of headman headers. Hoping I got a deal for what I paid and hoping the horsepower is what he says it is. Any input would be great.
Old 10-25-2010, 07:39 PM
SSedan64's Avatar
The Titanium Push Rods & Bolts, I would dismiss as not being there.
The Block # is a good one, 010 & 020 refers to the Nickle & Tin content.
Polished 202-20-77 Heads angle shaved to 0.50. = 2.02" Intake valves, angle milled .050" The -20-77 I have no idea. I doubt a 350 with an RV Cam will make 450HP.
There may be a Suffix number stamped on the front passenger side on Block that would give more Info. Should be a casting date on the rear of Block to the right of casting number.
Old 10-25-2010, 11:30 PM
Thanks for the info. I will look for the other dates stamped. I am now looking over the Engine better as I pulled the valve covers and the rockers look stock and are not roller rockers. The heads are stamped 338882 E-10. Any idea if they are 202 Heads or what they may be?
Old 10-26-2010, 12:17 AM
FastOrange's Avatar
Sounds like you got ripped off to me...
Old 10-26-2010, 09:50 AM
The Guy told me deep dished pistons cause it has a supercharger intake as he was going to supercharge the engine. I don't think he realized that I do have a bit of a clue on an engine and its components. He also said that it has an Edelbrock RV Hard Cam in it as well as Edelbrock HP Oil Pump. Is there any determining marks on these that I can look for to make sure they are in fact what he said. I am begining to think I have a plain Jane Chevy 350 with shiny valve covers and a ****ty supercharhed intake that I have no need for.
Old 10-26-2010, 10:39 AM
SSedan64's Avatar
The Oil Pump may have a Part# on it, you'd have to drop the Pan tho'.
The RV Hard Cam?? Solid Cam, no. There isn't a Solid Lifter RV Cam. So no idea on that. You could set up a Dial Indicator on a Rocker Arm & check the Lift or Install a Degree wheel on the Crank & check Lift and Duration. Cam Part# is on the rear of Cam so it would have to be removed to check that.
Old 10-26-2010, 11:30 AM
> I will pull the pan and start there and see what I can find. He said there were I-Beam connecting rods whcih are marine rods so they should be easily noticable. If you were to put a value on a stock chevy 350 rebuilt what would you value it at in canada. If done right.?
Old 10-26-2010, 09:29 PM
I dug my old Chevy Engine out from behind the garage. Wondering if it is any better than the first one I got hosed on. Casting numbers on the block are: 010
776509
G36
Stamped: 14016379 and another plate on oposite side says: H32 010
Cam is stamped: GM36 and 6930
Crank is Stamped: GM3982442
And the Heads are stamped: 462624 L69 on one and the other is H-18 or that is what they appear to say..
Any Help on these Items would be wicked.
Thanks Guys.
Old 10-26-2010, 09:51 PM
mud.man.rj's Avatar
optional 350's
The 3970010 block is used from 68 to 79 a good block with 010. usually 4bolt mains but may be a 2 bolt. The other block # is 1978-1979 only the h32 doesn't sound right as it is a date code, the cyl heads are from oct 1st 1978,as h is for the 10th month 1 is day and 8 is 1978. Not a good head low comp larg cc (76cc) emission heads.
Old 10-26-2010, 10:39 PM
ericnova72's Avatar
More for Less Racer
Looks like you got hosed, all stock parts and crap heads(one of the worst SBC head castings) to boot.
350 chevy engine backfires thru carb toms1940chevy Hotrodding Basics 8 09-23-2009 08:24 PM
Engine bolt sizes for 350 chevy eric32 Engine 6 05-02-2009 09:05 PM
Chevy engine ID, can anyone help id my 350 engine? Ron Garcia Hotrodding Basics 23 01-31-2008 04:51 AM
engine cooling specs for 350 4 bolt chevy downunder Introduce Yourself 2 10-02-2004 11:41 PM
untapped engine boss on 350 chevy Walker Engine 7 07-20-2003 10:23 PM
