any marker to use on bodywork
My car is now sitting in epoxy primer and I want to go round it marking all the little imperfections that were missed. Can I use any felt tip marker or should I use a particular type of pen?
On bare metal, I would use a sharpie brand marker. When you are done, it can be removed with acetone.
After the panel is primered, to be safe, use paints or primers compatible with what ever is on the panel, and will go on the panel. Acetone can soften a lot of paints, and primers, especially if they are fresh. |
This is the thing, why use a sharpie that CAN cause you all kinds of trouble when you can use a pencil that won't? A Sharpie will bleed thru paint like nothing I have ever seen. You can paint over it and it will come back so fast and severe you would think someone walked in the booth and wrote it on top of the paint after it was painted! The stuff is VICIOUS! As a painter I wouldn't have the stuff in the shop anymore than silicone spray. If something else will work, why chance it?
Brian |
I offered a type of marker. In the very next sentence, I told you how to remove any traces of the marker.
For what it is worth, it was suggested that a felt tip marker be used in other threads in this forum, dealing with rust removal, and metal finishing. |
Brian |
It WILL cause you trouble as has been mentioned above. I use a led pencil
They take a lot of abuse. They make a fat line easily seen and work great to shade an area you want to fix You can fill ,prime right over the led.
often I use a Dry-Erase type marker, especially when pursuing imperfections on cured clear...water won't remove it but a simple wipe with dry cloth will..
this kind--> http://www.buythecasesales.com/expoa...yeraseset.aspx if your using it for a guide on filler or primer then be sanding it all the way off there Last edited by milo; 01-27-2010 at 01:25 AM. Reason: common at Wallgreens ect. |
| Making good progress on bodywork now | Arrowhead | Body - Exterior | 7 | 11-22-2007 10:32 AM |
| Why do I struggle with bodywork so much | Arrowhead | Body - Exterior | 32 | 08-16-2007 09:12 AM |
| Bodywork - What steps to take...... | BeArDy | Body - Exterior | 4 | 07-06-2006 07:47 PM |
| No timing marker | GriffTannon | Engine | 3 | 06-10-2004 11:49 AM |
| Best method for eliminating a side marker | Indiana Red | Body - Exterior | 2 | 02-17-2004 08:04 AM |
