Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ANY one ever build one of the long rod engines.....
Old 11-02-2009, 07:17 PM
6sally6 6sally6 is offline
Well the article..........
was at purplesage.com. It was all about using the looong FoMoCo rods to build the torque while maintaining the 350 cu. in. Sort of a "the engine GM should have built."
My question is.....will these long rod engines re-act favorably with long duration camshafts?! ALL the article use these short no. duration cams. I know short numbers make more torque........but will the long duration cams work well with the long rod theory in a race application?!
