348
Not exactly what you have in mind, but that is what a 348 chev had for specs. I'm thinking the rods are 6.135"-ala the Mk IV big block. (348 is Mk I).
These were heavier, obviously, being the first big block, but they ran real nice. Real nice. Torquey. |
I had never heard of this before,and I could have got a dozen or more 300 rods for nothing a couple years ago,darn.
Shane |
I built the Hot Rod mag 400 block with 327 crank engine.
my variations were 10.5:1 compression , World heads with a larger runner then the 170, in the Hot Rod article. My results were good. It was put in a 71 chevy 4X4 with 3.08 gears,and a 350 w/ shift kit. Unladen weight was 5200 lb. The engine requires 14 deg. initial advance to run decent. The cam was an rv truck cam. It ran with no problem with 82-87 octane. it would break the tires loose with little throttle position. The pipes were twice as loud with the same headers a stock 350 engine. Man it is great having gray hair . The cops just shake thier heads when it was wound out. |
350 cubic inch race engine making 400 hp?
long rods vs short rods? will it make a difference? sometimes,,, depends on rpm,combustion chamber,ie fast burn.fuel used ,piston dome shape, head material,,so basically everything. The piston goes to the top of the bore,stops,reverses direction and stops then does it over and over.The piston accellerates from stop to, w/e,then decellerates.there fore the speeds in the bore are different rates depending on where in the bore the piston is atm. A short rod and long rod have slightly different angles just after tdc so the excelleration rates will be different for each piston. The flame propagation will be different from one head to another,fuel burn rate different,and many other factors. Many engineers coundnt form a mathematical formula for every situation. |
| Factory Five Racing '33 Hot Rod Build | Arrowhead | Hotrodders' Lounge | 3 | 08-02-2009 06:49 PM |
| lookin to buy or build a rat rod | lookin4ratrod | Introduce Yourself | 6 | 03-11-2008 05:35 PM |
| 454, Long Rods, and Nitrous, oh my | 83Silverado | Engine | 1 | 03-31-2006 09:26 AM |
| longest rods in std deck 454 bbc?? | deuce_454 | Engine | 11 | 01-30-2004 10:06 AM |
| Long rod 302 | 2wld4u | Engine | 4 | 07-29-2003 04:36 AM |
