any one using a edelbrock rpm cam ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2006, 05:53 PM
jbon64
was wondering if anyone here was using a edelbrock rpm cam in a SBC 350. would like to know what the idle sounds like and how streetable it is .
Old 08-02-2006, 06:05 PM
kain13's Avatar
nice had motor in car for 9 months until car was stolen but idled around900
rpm heads cam vic jr intake 750 dp holley real nice cam will use again
Old 08-02-2006, 06:14 PM
nitro_baller4692's Avatar
floppers forever
i never put one in a chevy, but did years ago put an edelbrock cam, springs, intake and carb on an olds 455.it run ok but i swaped the carb and cam for a holley and a comp cams cam shaft with the same spec.and what a difference.
i will never use an edelbrock cam shaft again.
the only reason that i used it then was the customer was trying to do the economical build to make power,and that was wrong.but he insisted that it was a matched kit and would work best boy was he wrong.if i remimber correctly there was a 75-80hp increase.
i'll look and see if i can find a copy of the cam card and dyno sheet,not sure if i still have those because i don't work a the same place.
Old 08-02-2006, 07:20 PM
jbon64
did the idle have a nice lope to it ??
Old 08-02-2006, 07:47 PM
kain13's Avatar
yes it
Old 08-02-2006, 08:25 PM
spankys rod shop's Avatar
rpm cam.
I have a complete rpm package (355) cubic inch in a 1963 chevy pu. really sounds great, the idle sounds meaner than my drag car. but if you are considering using the rpm cam you will need some stall, depending on the weight of your hotrod, at least 2500 to 3000 or it will be a turd off the line .
Edelbrock cam Dbodily Engine 3 10-27-2004 12:02 PM
Edelbrock's RPM cam? bowtieorbust Engine 4 11-09-2003 11:25 PM
Raising the Redline Hollywooding Engine 23 07-17-2003 10:19 AM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
