Any Other Cups Fit an Iwata LPH 400? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2011, 07:54 PM
Hello everyone. I'm new to the forum, been visiting a lot but never have posted. I was hoping someone can help me - does anyone know of a less expensive paint cup which I could use on an Iwata LPH 400?
Might go with the Mix and Spray but I thought I had seen someone post that an Astro cup fits their Iwata. Plastic or metal OK.
I appreciate any help you can give me.
Thanks,
Jeff
Old 09-17-2011, 05:40 AM
Harbor Freight sells a cheap gun for $ 9.99; with coupon in many car magazines. Although not a great cup it will work with the Iwata. The gun looks just like one of my cheap Astro primer guns & all the pieces of the Harbor Freight gun will interchange with the Astro.
Old 09-17-2011, 01:09 PM
mitmaks's Avatar
Last journal entry: Grille
Personally I bought this kit, they're cheap and work on my Satas, I would imagine they will work on Iwata also
http://www.harborfreight.com/5-piece...ups-97098.html
or you might try this one if your gun has male adapter
http://www.harborfreight.com/33-oz-g...cup-38518.html
Old 09-17-2011, 07:07 PM
Thank you both for the replys.
mitmaks - do you use the disposable cups one shot or do you clean them? my gun does not have a male adapter. Do you think I can just buy a nipple and use that as an adapter?
Old 09-17-2011, 07:15 PM
mitmaks's Avatar
the plastic one came with male adapter, actually 2 or 3 if I'm correct, different treads. I clean mine as I'm not rich enough to throw away things after one time use lol
Old 09-17-2011, 08:09 PM
thank you for the reply. i would probably clean them also. Did you have any bad experiences with leaks and so forth?
Old 09-17-2011, 08:20 PM
mitmaks's Avatar
no leaks. Also I'd like to point out that they're clear so it's convenient seeing how much paint/clear you have without stopping.
Too bad they don't have 33 oz ones so you could shoot longer without stopping.
Old 09-17-2011, 08:40 PM
That was kind of my thought also. Use the "disposables" except when you want the large capacity - then use the aluminum one.
3m pps cups showtime1k Body - Exterior 2 06-21-2011 08:20 PM
Do I have the Right Size Valve Spring Seat Cups?? texastomeh Engine 2 01-17-2011 12:24 PM
HVLP replacement cups Bart Body - Exterior 3 05-07-2008 06:12 AM
Plastic vs. Metal Cups SHIFTY101EASY Body - Exterior 5 02-09-2007 11:46 PM
Aftermarket spring cups or let the springs rest on a shim? sizemoremk Engine 3 01-13-2006 02:51 PM
