Any particular order ?
I'm in the process of installing the rear brakelines on my '41 Chevy. I'm putting in a residual valve, proportioning valve and a low pressure brake light valve.
Is there any particular sequence that I should observe ? I've seen a number of configurations. Any suggestions would be appreciated. |
I'm not sure of the low pressure brake light valve. Do you mean low pressure switch? For the remainder - master cylinder then residual pressure valve then the proportioning valve.
Thanx for the quick reply. Yep it is the low pressure switch, it also operates brake lights.
I think that they suggest you put the brake light switch as close to the master as possible. That is for an inline switch. You can also use a mechanical switch that is activated by the brake pedal assembly.
Thanx Home Brew. I'm considering a mechanical on the brake pedal. The inline is just one more plce for a leak
| Firing order and Distributor | colincamaro | Engine | 3 | 12-27-2006 04:27 PM |
| firing order | FordTrouble | Engine | 8 | 11-27-2004 11:22 PM |
| Intake manifold bolts order? | nicowarrenrogers | Engine | 5 | 08-22-2004 04:31 PM |
| Firing order wont work | delory | Electrical | 15 | 05-07-2004 11:22 AM |
| Meaning of the iron cross? | FASTCHEVY | Hotrodders' Lounge | 15 | 03-05-2004 11:01 PM |
