Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Any problems spraying carb cleaner in my carb while its on the motor?
Old 08-13-2004, 09:54 AM
Centerline Centerline is offline
Wiki Edits: 49
We used to do this all the time. You need the engine to be running though. Just spray the cleaner down the carb, and keep the throttle up a little so it doesn't stall. You'll get tons of white smoke out the pipes but not to worry it will clear in a minute. This method used to be considered the poor mans way to clean a carb.
Centerline
