Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Any rear end rebuild advice?
Old 05-06-2003, 10:28 AM
tommytempest's Avatar
tommytempest tommytempest is offline
Post
Thanks for the list! A guy probably ought to pull the outer bearings and seals at the same time huh? Is a slide hammer required to pull the outer bearings? I actually put a new pinion seal in it last weekend and it does still leak a bit but not near as much as it did. I need a sleeve to cover the old groove in the yoke to fix that. The crush sleeve is more of a spacer than a seal surface.
Tom
