Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Any Reason to run SAE 30 vs 10W30 ?
Old 07-14-2009, 03:48 PM
y2k600f4 y2k600f4 is offline
Is it a flat tappet(lifter) cam in the engine?
AND
Are you using the Valvoline Racing oil straight 30?(I think it says VR-1 on the bottle)
The building may be insisting on this cause that VR-1 has a higher zddp package(wear additives) in it which will help your cam and lifters lifespan
You should always follow the builders recommendations, especially if you have some sort of warranty with the builder
Yes it is flat tappet,however he is recommending just nornal 30W (just particular to valvoline); did not recommend anything regarding oils with high ZDDP. Honestly I think he may not keep up 100% with the current trends.
