any suggestions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2005, 06:55 PM
any suggestions
does anybody have any suggestions for what i can do to give my 78 ford pickup any more power and does anybody have a positraction or locker that they are willing to get rid of. the engine is a 302
Old 11-17-2005, 08:06 PM
"70" Cougar's Avatar
Meat-Head Extroidenaire
i would probably do the regular things .. like headers and exhaust, check the transmission (if auto mabe a stage 2 shift kit) that locker would help mabe traction bars . Motor wise i would say depending on the shape of the motor , maybe an intake and some head work and a carb. You see theres soo many different things to do. Your only question is how much money you wanna spend and how much time you have .
OH and my first truck (vehicle ) was a 77 f150 three speed on the colom with a 351m . I love those ol trucks and still own the fist and another only this won is a 79 250 4x4 with a 429 . keep me in the know about you ride if ya dont mind .(y)
have a good one
bill
Old 11-20-2005, 11:47 AM
Tazz
did you look here?
www.summitracing.com Summit has a whole section in its catalog on the sbf engine hop up parts.
tazz
Old 11-27-2005, 04:12 AM
well , as ford guy and a fan of the 302 i'll have to say that you need to start with the bolt on's. start with headers and exhaust, then get that ole carb and intake off there . unless you plan on changing out the heads get a holley 2- barrel carb and edelbroke intake. that will give the ole truck a little more pep in her step. but if your looking for more than a little pep, you gotta get those 2-barrel heads off there and not spend wasted money on the 2 barrel carb and intake. If the motor is in good shape and you want a noticable power diff. I suggest you change the heads , cam ( complete matching valve train ) intake and carb ( 4- barrel ) , headers and exhaust. And as for the posi lock , i assume you still have the stock rear end and a used posi will be hard to find. Better off in the long run to buy one new and be done with it. while your in that rear end you'll be money ahead to rebuild it while you have it apart.
383 stroker assembly/variant to their suggestions 57NAPCO Engine 1 02-12-2005 11:23 PM
Suggestions on the best flux core wire? 357ford Body - Exterior 3 06-08-2004 11:23 AM
Exhaust Suggestions rbfpezcore General Rodding Tech 13 12-12-2003 12:11 AM
Tuning Suggestions for a .30 over 350 69malibu Hotrodders' Lounge 10 08-20-2002 07:57 PM
