any thoughts on the 049 heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 08:01 PM
chevykid90's Avatar
454, what turns your crank?
Last journal entry: Replacing bearings and crank
i am building a 454 to put in my 81 firebird and have 3 sets of heads to chose from. i have 292, 236 witch i am most likely not going to use, and 049. the block has been bored .030 by the person prior to me other than that i am making a mostly stock motor. not going for high horsepower motor. its my first big block build so i am taking baby steps.
Old 06-14-2010, 08:05 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The 049 heads are the only viable choice of the three you mentioned for a performance build. The 049 heads are open chamber so CR will be low unless there's some positive dome to the piston.
They respond well to larger valves and pocket porting to clean them up- this is true whether or not you cut them for bigger valves, but is a necessity if they're cut for the big valves. If you don't, there's a good chance they'll flow less than w/the OE valves in them.
Old 06-14-2010, 08:10 AM
chevykid90's Avatar
i couldn't find anyone around here that had a set of closed chamber heads that were in my price range. but in my numbers book these heads had the smallest chamber size with 112cc. i am not going into having bigger valves put in, but will porting them give me any significant gains?
Old 06-14-2010, 08:28 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you can do it yourself, there's something to be gained in many cases, by smoothing the transition from where the factory tooling cut the last angle into the port. There is almost always going to be a "lip" that interferes w/the flow, as well as the usual casting flash and irregularities that occur as a matter of course in mass produced iron castings like these heads.
There's not as much to be gained by porting the runners, the "low-lying fruit" is said to be the bowl. A three angle valve job done correctly will be an enhancement that will likely be as much of a gain as anything else you might do, so be sure and have that done.
A 30 back cut done on the valves is also helpful, and doesn't cost a fortune to have done.
There are reduced diameter valves available for your BBC. The entire stem isn't reduced- just the portion that's in the bowl area of the head. I've not used them, and I have heard conflicting reports of how much is gained by using them. If your research shows them to be beneficial- and IF valve replacement is needed anyway- they'd be an option worth considering.
HiPo heads RJL Engine 16 06-29-2009 10:18 PM
049 Heads Glenn Holt Engine 8 12-17-2007 12:07 PM
getting old iron heads to flow? (SBC) KNanthrup Engine 9 12-21-2005 06:06 PM
FE blocks SAATR Engine 27 03-14-2005 05:35 PM
sbc heads Jared Engine 7 03-03-2003 08:07 PM
