Is there enough space to fit an angle grinder or the end of a Dremel in at an angle where you can cut the bolt.? If you can't cut through the bolt itself, you may be able to grind the bolt head off or cut through the nut.
If you can see the bottom side of the nut, use the grinder to cut through it up to the threads and it should break loose from the bolt. Just make sure you use good goggles (that seal around your eyes) when you do this because you are going to be under the car looking up at the bolt, and small metal chips go everywhere. For a badly worn bolt head/nut I've also had good luck with clamping vice grips around each end. Then slip a section of metal plumbing pipe (like from Lowe's) around the vice grips handle to give you more leverage. If you can get the vice grips to clamp securely, you can get a lot of leverage this way. One vice grips usually hits the car as it rotates (so it holds it) and you just apply the torque to the other one using the pipe extension. Bruce |
stuck bolt.......
Hi,when ive tried every other way to remove a frozen nut (or bolt) i drag out the hot wrench (cutting torch) but,i try to put a piece of 18 or 20 guage sheet around it to act as a spark guard. from messing something else up.
backhoe time
A friend was using a trans am for his donor drive train for his 39 chevy, After he was fighting the rear suspension for half an hour I checked how he was doing. I had dropped the front clip. I just fired up the backhoe, turned it upside down The body was going the the recycle yard. and we took a BFH and made access to use the impact wrench. NOt the way you want to do yours.
| My First Cutting Torch - Tips and Tricks | nine4gmc | Garage - Tools | 8 | 05-24-2012 08:14 AM |
| welding tips/ mixing featherfill tips | tech69 | Body - Exterior | 1 | 04-16-2011 02:15 PM |
| bushing driver- trans. pump bushing. | Chevy350Sb | Garage - Tools | 2 | 10-14-2009 09:45 PM |
| TH350 bushing ? | 6426yy | Transmission - Rearend | 2 | 05-21-2008 07:33 AM |
| Is this bushing correct? | 2ManyCars | Suspension - Brakes - Steering | 10 | 06-13-2005 03:06 PM |
