Any tips on dodge 518 Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2005, 07:28 AM
Last journal entry: Latest picture
I picked up a dodge 518 non-lockup transmission to go behind a crate 360 for a street rod I'm building. I've rebuilt many 727's but never a 518. Anything I should look for? will the 727 converter fit?Thanks. Dan
Old 02-16-2005, 06:05 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the front section of the 518 is basic 727....
the OD section needs special tools and a press of some type (hydraulic or arbor) to rebuild . if you do not have them you can get hurt by the large coil spring inside the OD section.
Old 02-18-2005, 08:28 AM
depending on the year of production, the trans may need some upgraded parts. Find a performance minded trans shop. The OD section in these transmissions can cause REAL heartache. Expensive, broken heartache.
