Any tips to lube old heater cables - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2006, 11:04 PM
murrsue's Avatar
Last journal entry: 57 pickup 8.8 rear axle install
I'm stripping down a 57 chev truck cab to prep for paint. There's a lot of push/pull cables for heat, choke, vents,etc., and I'd like to lube them up for smoother operation when I reinstall them. Any tips?
Old 01-23-2006, 05:27 AM
poncho62's Avatar
Wiki Edits: 5
If you are removing them, soak them in a pan of oil for a few days and then wipe them off. Ir leaving them on, spray them with WD-40.
Ontario Rodders
Old 01-23-2006, 06:06 AM
302 Z28's Avatar
I agree with Poncho62 up to the point of the WD40. WD40 is terrible for lubing cables. After the carrier solvent has flashed off it leaves behind a yellowish goo that will gum. Yeah it will work great short term. I would use something made for cable lubrication. You can find some dynamite cable lube at the motorcycle shop. BelRay is but one manufacturer.
Vince
Old 01-23-2006, 04:25 PM
poncho62's Avatar
Wiki Edits: 5
Didn't know that..............................
Ontario Rodders
Old 01-23-2006, 08:19 PM
FiveFeezy's Avatar
Fishing poles in the hot rod!
Sure is a good idea to lube them. If they get too stiff your heater controls can break. I squirted Liquid Wrench in mine and they loosened up fine. Don't know if it has the same problem as the WD-40 or not.
Old 01-23-2006, 08:31 PM
46chevyfleetline's Avatar
Last journal entry: A few more
Since you live in Canada, try Release. You can get it at Can. Tire. Green and yellow can I think. at work i pull the cables out and hang them and start putting the penetrating oil to it. Them hang them the other way and do it all over. Krown also makes a good pen. oil and lube. I hate to put down a product but wd-40 is the worse by itself. It cleans the metal too good. Had a buddy clean his guns with it and after a month they where rusted so bad he had to get some of them reblued. Let us know how you make out. Cheers!!
Old 01-23-2006, 08:33 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
I will use WD-40 or similar product to penetrate & as a vehicle to get lube in there I would try to soak then in a synthetic oil so it will last longer
After soaking hang them up & let them drip out so after they are reinstalled they wont leak on your dash, feet & floor
White lithium grease's probably the best because it will go in ,in a liquid state & then congeal to a grease state.
Well I hope this helps!
Rob
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 01-23-2006, 08:58 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
Rob
Depending on your climate... anything that "congeals" would sure as heck freeze up solid at -20°C (around 0°F). I learned that an an early age on an old snowmobile .... yeeeehaaaaaaw!
Graphite works well. You can buy it in an aerosol can and spray it right inside the cable housing. After the liquid "carrier" evaporates it leaves the dry graphite powder behind. Graphite doesn't care about temperature ... it's always slippery. Don't overdo it if the cable is installed in the car, though ... it can make a "mell of a hess" on your carpets.
Old 01-23-2006, 10:58 PM
murrsue's Avatar
Thanks fellas,
I think for the ones that I can pull the inner wire completely out of I'll try the graghite spray in the housing but some cables ends are bent at the end where they hook up and I can't separate them from the housing so on those I'll have to try the oil. Murray
Old 01-24-2006, 01:53 AM
Might try some BreakFree CLP.
Old 01-24-2006, 07:17 AM
Rob Keller's Avatar
Wiki Edits: 38
What is this??
I forget about the cold weather guys its a mental block thing ...mind over matter ?if I dont have a mind it don't matter
Rob
"SlowRide66"
Old 01-28-2006, 06:50 PM
My 2 cents
Also at a motorcycle dealer you can get a cable luber for the ones that dont come apart. Basically a small aluminum shell with a rubber insert. It fits over the cable end and you tighten it with two thumbscrews. It has a small hole for the straw on the lube can so you don't waste as much. Motorcycle chain lube works well.
Old 01-28-2006, 06:59 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
I have used 3 in one oil before and it has worked pretty good
Old 01-18-2010, 08:27 AM
Royal Purple
Dunno if I'm going at it right, but I use Royal Purple (used) on my Avanti & it works great!! I paint it on with paint brush, simple!! I live in So East Tx so cold is not a problem SEAYA !!
Old 01-18-2010, 07:37 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Let's put this thread in General Rodding Tech.
Dan
Need help deciding on garage heater Xenocide Garage - Tools 20 01-05-2008 09:54 AM
Engine Assembly Lube ? bowtieorbust Engine 11 11-09-2004 11:24 AM
Heater has mysteriously stopped working. HotRodMan General Rodding Tech 8 12-29-2003 04:38 AM
Heater Cables Travelinman Interior 5 10-24-2003 04:53 AM
Heater control valve question HotRodF100 Engine 2 05-23-2002 03:15 PM
