any tips for removing a stubborn rear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2005, 10:46 PM
I am in the process of removing my 8 inch ford center section. axles are pulled and nuts are off of the thing but I cant get it to budge. any tips on breaking it loose. can I hammer on it pretty good without worrying about breaking it?
Old 04-22-2005, 12:37 AM
aka Duke of URL
Try putting the U-JOINT clamps back on the flange and use a large pry bar to try and pull it lose (side to side). This will prevent any damage with a hammer or pry bar.
Old 04-22-2005, 08:21 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
when i had this same problem i just used a screwdriver or thin chisel & tapped it w/a hammer around the outter edge of the 3rd member(where it goes into the housing) untill it broke loose. never had a problem doing that & never damaged anything.....joe
Old 04-22-2005, 11:12 AM
I agree with the screwdriver approach I had the same concern on my 8 inch and it was a similar chore to re-install it. If the AH who installed it put the latest easy way of a sealer instead of a gasket you probably got to fix that also.
Old 04-22-2005, 11:17 AM
well im pretty sure that this thing hasnt been off since 1970, and I can see the gasket, the screwdriver just feels like its hitting solid metal instead of gasket. I might nee to jack the car up a bit more so i can get a good swing at the screwdriver. it also looks like there is no play around the bolts. thanks for the input.
Old 04-22-2005, 06:37 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
VoodooSurfer,
The center section fits real tight. If you installed it yesterday, you would still have to pull and wiggle at the same time, to get it out. If the center section hasn't been out in 30 yrs, it's even tougher. I would try a putty knife between the section and housing( go around as much as possible. Then try the screwdriver/prybar on the yoke (just wiggle it side to side, up and down). After you have movement, you should be able to wiggle by hand and pull.
Bob
Old 04-23-2005, 03:27 PM
thought I would update everyone. very simple to pull off. once you remove the almost invisible copper washers that snuggly fit around the bolts.. once I got those off it popped right off. thanks for all the tips I appreciate it.
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
8.5 vs. 12 bolt rear somethin4nothin Transmission - Rearend 5 04-06-2007 04:18 PM
1945 ford p/u rear leafs,to keep or not to keep biglee550 Suspension - Brakes - Steering 8 04-25-2005 07:05 PM
camino rear bushings and pwr. str. pump tips??? HARVICKx29 Suspension - Brakes - Steering 5 01-19-2004 12:02 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
