anybody elses edelbrock carb have trouble? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2003, 02:03 PM
mustang66maniac's Avatar
Ford Freak
Post anybody elses edelbrock carb have trouble?
My edelbrock carb works fine around town, but when i get on it from a dead stop, something in the linkage catches up.....and the secondaries wont open! If i take off slowly, then gradually floor it, then the secondaries WILL open. I think something from the electric choke swings back from the sudden movement and catches the linkage stopping it at half throttle???? Does anybody else have the same experiences with their edelbrock? I went to the drag strip last night and embarrased myself after going down the track with a 2 barrel carburetor.
Old 02-06-2003, 02:10 PM
dmorris1200's Avatar
doesn't play well with others
Post
Should've bought a Holley. <img src="graemlins/nono.gif" border="0" alt="[nono]" />
Sorry man had to do it.
BUILT FORD TOUGH
Old 02-06-2003, 02:33 PM
5.0Towncar's Avatar
Post
Holleys suck donkey balls. I had a Holley 2-barrel on my 82 Dodge Omni and it always would get out of adjustment.But it ran fine the day I sold it .Steve
Old 02-06-2003, 02:47 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
Just from curiosity, How do you know they don't open. Just in case you don't know they won't open untill you reach something like half of the total CFM the carb is rated for. Just wondering if you are staying in the throttle long enough to generate enough air flow.
I apoligize if this is a stupid question, How ever, I have seen many people make this common mistake.
Old 02-06-2003, 04:01 PM
DoubleVision's Avatar
Post
Shoulda got a Demon.
Old 02-06-2003, 04:05 PM
Post
Maybe it was just that your Omni sucked donkey balls.
BUILT FORD TOUGH
Old 02-06-2003, 04:14 PM
5.0Towncar's Avatar
Post
Yes it sure did.....The only thing I did which was fun was take some trans fluid and rub down the tire tread with it and lock up the e-brake and punch it...nothing like smoking front wheels. Steve
Old 02-06-2003, 04:28 PM
Post
I've done that too ! Not with an Omni either. I used to take cars out to the back of the dealership parking lot and drag them across the lot with the front tires smoking and the rear tires just dragging along.
BUILT FORD TOUGH
Ford Freak
Post
jason, the linkage would actually get stuck and the pedal would not go past halfway to the floor....without breaking something that is.....wait, theres an idea!
I think im going to get a 650 demon as soon as i get some dinero
Old 02-06-2003, 07:21 PM
mstngjoe's Avatar
Post
Before you dump the Edelbrock, try a couple of things.
Warm up the engine and shut it off. Remove the link (A) and attach a small wire to hold the choke plate all the way open. Take it for a test drive and see if the problem goes away.
Also check to see that the secondary link (B) is in the rear hole.
Old 02-08-2003, 06:32 AM
Post
I've got an edlebrock 600cfm elec. choke, I really like it, it's on a 350 bored and balanced, flat top pistons, speed pro cam, edlebrock performer intake, vortec heads.
Make sure the choke is fully off, the design is to prevent secondaries from opening until the engine is at operating temp. You might need to make a minor adjustment.
