Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Anybody good with fiberglass
Old 06-26-2012, 12:45 PM
rusthater89's Avatar
rusthater89 rusthater89 is offline
Originally Posted by wwilliams181
The epoxy resin as stated above is the trick.. don't think gm used Polyester based resins since 1970. The normal polyester you get from the local parts house will not adhere to the part.
I'll have to research that later. I put the fiber-glassing I did over the epoxy primer. Hopefully that is better.
