Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Anybody got the 110V 135A eastwood mig?
  #33 (permalink)
Old 10-22-2010, 06:19 PM
oldred oldred is offline
Originally Posted by roger1
IMO, if your primary welding will be welding 1/4" to 1/4", then you should consider a larger welder. But, if 1/4" is only occasional and your primary welding is smaller, then this is a great size to get.
That is a very good point and one that I should have made when talking about using that 110 machine to weld 1/4" and thicker, I just assumed that his primary purpose was to weld thin sheet. My point was that the 110 outfit could weld heavier stuff in a pinch with proper prep but you are exactly right a 110 volt MIG should not be considered for heavier than light sheet metal except for an occasional small job.
