Anybody got a Mustang II crossmember laying loose or on the car but bare? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2005, 11:22 AM
SinistrV6's Avatar
valve monkey
I'd like a measurement if you have one. I'd like to know how much material is there between the bolt hole for the lower control arms and the outside edge of the crossmember. Mine has 1.75" of 1/4" steel from the center of the bolt hole to the edge of the crossmember and it's hitting the LCA when it travels upward. I'm curious if I can trim this (considerably) without weakening the crossmember. The one in my car is a Fatman's but it is probably over 10 years old. Maybe they've made some changes over the years??
____________________
\__O___________O__/
Crossmember drawing (crude)
Old 08-03-2005, 07:52 PM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
SinisterV6,
If you still need the dimension let me know. I have a Heidts and a Fatman I can check after returning home from Louisville.
Old 08-04-2005, 03:57 AM
SinistrV6's Avatar
valve monkey
Thanks
Thanks, A.D. I'd appreciate that.
Old 08-07-2005, 05:10 PM
The dimension on the Heidts for a '35 Chevy Master is 2 1/4" from the center of the lower control arm bolt to the outer edge of the Heidts frame as measured in a plane level to the floor.
The Fatman built for a '48 Chevy pick-up measured 1 1/4" as described above. There was more material on the fatman above this level to the floor plane plane but I did not measure those dimensions as I had no ready reference.
Hope the information helps.
Old 08-07-2005, 08:08 PM
SinistrV6's Avatar
valve monkey
Thanks A.D. That's a big difference between manufacturers! Mine's a Fatman's so I guess I could take another 1/2" off if necessary.
Old 08-08-2005, 05:11 PM
Sinisterv6,
I wonder why the lca is contacting? Don't know how old the Fatman is in my '48 so there may have been a change at some time. Maybe you could touch base with Brent.
Are you building a '36 Chevy with a Buick turbo V6?
Old 08-08-2005, 07:15 PM
SinistrV6's Avatar
valve monkey
I contacted Fatman's and they didn't really have an explanation. Moving it 1/4" forward removes the problem (see my other thread on centerlines).
Yes on both the car and the motor.
"Basics of Basics" Photographing your car. MARTINSR Hot Rod Art 89 03-31-2009 02:53 AM
Mustang II pressure regulator Chev283 Suspension - Brakes - Steering 1 07-14-2004 02:13 PM
mustang II ifs specs Blob Suspension - Brakes - Steering 1 12-24-2003 09:48 AM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 12:43 PM
Mustang II front end Question horvath Suspension - Brakes - Steering 35 03-02-2003 04:08 PM
