Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Anybody have any thoughts, burning hydrogen
  #81 (permalink)
Old 03-07-2012, 07:44 AM
matt167 matt167 is offline
Wiki Edits: 31
I never said it couldn't work. It's not working by burning the hydrogen. could be as simple as throwing sensor values running it a little leaner than it should be. As long as it remains in range, there will be no code set...
Put it on a scanner with the setup, and then turn it off. see what sensor values change. you should see a change with the O2 sensor and possibly fuel trims if somthing's happening as you say it is.
