power used
for hydrogen on my car is 4 amps at 12 volts which equals 48 watts whooopeydoo, a head light takes 4 times as much. and 1/4 tea spoon of baking soda with 16 oz of distilled water. I can get 220 more miles per tank full on a trip with this unit.if I got 20 mpg which i don't that equates to 11 gallons of gas at $3.83 a gallon right now. That's $42.13 saved every tank full. How can any one in their right mind argue with this. I am dumbfounded by the reasoning by some about this wonderful find. Its like every fill up Exxon gives me 11 free gallons of gas. only bad part is I have to bring the jug in on cold nights so it don't freeze. I can live with that easily. look on Ebay and see how many are selling these and there has to be many more buying them i am one. I can make my own but they are cheap enough to buy on line. Technology will leave you guys behind soon if you don,t start to think outside the box
Why don't
you try taking some of your physics and empty your bowels as you are full of BS. This works and this throws all your preconceived notions on what you believe to be true in the rubbish. This is why America cant move forward on many things blind folks like you and other greedy ones who want to protect the oil industry. All the working units all over America puts all you fault finders in a bad position, similar to the finger pointers at the Wright Brothers Had any of you took the time to go in the field and see these working units, you would then see the ignorance that has had grasps on your thinking. I pay less you pay more because of ignorance and stubborness heheheeheh
First let me first appologize for being a greedy crook oil man for the past 40 years producing all that evil gasolne to power your GTOs and Vettes. I'll think about repenting but it will be hard in view of the obscene profits I have made all these years.
Let's look at your machine with a little engineering logic. I realize that makes the analysis bogus but humor me, I was trained to think logically. You claim that your machine improves the energy output of a given volume of gasoline 50%. If that is the case (follow the logical progression here), would not adding a second machine to your car double the energy output of any fuel used in the engine and allow elimination of all the gasoline? Now you could run your 150hp engine on 100% on-board generated hydrogen thru a couple of ~6hp alternators. Now I have to resort to that ignorant, unenlightened engineering education I got but again, humor me, I got my learnin' from college, not You-Tube videos. Since an internal combustion, 4-cycle engine (Otto cycle) is capable of 20% to 25% thermal efficiency, the alternators are ~95% efficient, and the electrolysis process is only ~80% efficient unless you are using platinum electrodes, your machine is 8 to 10 times more efficient than previously theoretically possible! Stated another way, the hydrogen you generate contains many times more energy than the gasoline (or hydrogen) burned to generate it. It follows that the hydrogen you generate will have more energy than any fuel used to generate it. Thus you could power ~15 or so alternators from your engine generating hydrogen. Only 2 of the alternators are need to run your engine so the excess hydrogen from that engine could power more engines generating more excess hydrogen. That could go on infinitely and the whole world could be powered from free hydrogen. Again, the lure of perpetual motion machines (be they hydrogen generators, 100mpg carburetors, complicated rotating weight and lever machines, rope and pulley contraptions, there have been infinite perpetual motion machines proposed over the centuries) is strong and folks have always and will always fall for them. |
You are a Moderator
your math
is faulty I have a working unit,, hehe thats better than your mud slinging. I have college also but I never said I was a know it all, except I know what I have and it does the job , heheh for 3.5 years.Proof is far better than accusations. There are to many chicken littles in this Country.
My setup
Well guys I have had quite a tongue lashing from some in this forum. About hydrogen generators for cars to save gas. I am 68 years old and can usually tell when I'm being ripped off or tricked. That comes from experience of being around this long. I have some photos of my hydrogen generator that is in my Ford Windstar. It has been in the Van for 3.5 years and I keep it going by refills and new coils every 6 months or when needed. Does anyone in here think I would have kept this in my car for this long if it did not do what I claim it does? I originally posted this idea to help others who may want to save some gas during this gas war with outrageous prices. But evidentially even some Moderators in here have bashed this all to hell. This is not a gimmick I have no reason to lie or trick anyone just help them out like I am enjoying when I use this unit. As I mentioned earlier in the forum I usually get a 10 mpg increase when I go on a trip and drive at 60 mph. Around town 4 to 5 mpg increase because of the speeds in my country roads. But 4mpg increase is major to me. I have a 22 gal tank and that amounts to 88 more miles I can travel on my back roads. 88 more miles is around 4 extra gallons of gas I did not have to pay for.4X $3.83 around 14 bucks worth. I will post some photos of my set up in my Ford Windstar van. This is a simple canning jar for strength, distilled water because it has no pollutants in it. !/4 tea spoon of baking soda. 12 volts running to a stainless steel wire coil and some rubber tubing. An Aquarium blow off valve set at about a lb. The intake sucks up only what is generated and burns it in the combustion chamber. How and exactly what it burns i don't know, if its Oxygen, hydrogen, but I don't care it increases my gas mileage. It costs me 35 dollars to get set up 3.5 yrs ago. All this stuff is available online run a search for HHo or brown gas. Brown gas is the term for the baking soda as it turns brown when it is being charged with 12 volts and is generating. That's it in a nut shell no big scary thing. Easy as pie to do. Some cars have problems accepting the Hydrogen because of the computer on board. My van took the gas well with no changes. I had a 1995 Escort that would not take it. Here's some photos.
Hydrogen on demand
This unit does not store hydrogen it uses all it makes as long as 12 volts is applied to the coil. The blow off valve lets extra escape to the atmosphere so it cant build up. The vacuum source i used was from my PCV valve and I injected the hydrogen just before the butterfly valve for the intake the gas mixes with the incoming air and ignites along with the cars gas. This is not for commercial use as I have never stated this or implied this. This is for you the home owner and car driver who does not want to make investments to Bomb Belt schools everytime you buy gas from the pump.
My van photos
some photos did not post
I read this article. It confirmed my thoughts that the H2 generator mentioned here is not only innefective but dangerous.
Please read this. The guy knows what he is talking about. http://answers.yahoo.com./question/i...4131643AAsFG8U I apologize if this curbs your enthusiasm, but it is a good reality check as it shows the math and hard fact involved with running hydrogen. Those E Bay sellers are hosing people. The E Bay generators make around 3 liters of uncompressed gas per minute(under Ideal conditions). Your van needs 700-825 liters per minute to run at 60 mph. Even adding the 3 liters per minute would not provide enough offset in fuel supply to give the results you are saying it provides.3 liters isnt even 1% of the engines fuel requirement. I doubt it would give any increase in mileage whatsoever. Last edited by latech; 03-03-2012 at 05:32 PM. |
By your math you are getting 220 more miles on 16 oz. of water or more than 13 miles per oz. That is pretty impressive but not too plausable.
read the info
HHO Generator
HHO Generator HHO generators uses the basic and very old process of electrolysis of water (H2O) to convert it to its gaseous state (HHO). For a car, truck or other vehicle, the HHO generator fits either under the hood or in the trunk or bed. Once the HHO generator creates gas from water, this is then injected into the vehicle's intake system. The hydrogen and oxygen (sometimes called hydroxy or oxyhydrogen) helps the gasoline or diesel fuel burn more cleanly inside the cylinders. This clean burn means fewer emissions and increased gas mileage. It must be noted that both hydrogen and oxygen are flammable and combustible in the gaseous state. How HHO generatosr work exactly has been a debate for years. Ever since William A. Rhodes (Rhode's gas) and Yull Brown (Brown's gas) applied for patents in the 1960's and 1970's concerning HHO gas and showed its use in welding applications, critics have been calling this snake oil, scams, and other choice names. What the critics have yet to explain however is the fact that it actually does work. Yull Brown used an HHO torch to weld materials and even burn himself on the forearm to prove that an HHO generator can produce clean gas with a high temperature (over 6,000 F). A company that Rhodes started in Phoenix, Arizona called Arizona Hydrogen Manufacturing is now selling HHO generator based welding machines that electrolyze water to create the gas for a high temperature flame. It's hard to call something snake oil when there is irrefutable visual evidence that it works. So, because HHO gas is not well understood on an atomic scale, some people tend to pan what they don't understand. But, nevertheless, HHO generators are here to stay as their demand in the automotive industry increases daily and their use in the welding industry is also a hot commodity. Technological conservatives will soon give way to the progressives on this one. |
Grandpa01
The water stays for about 3 weeks and then I add more distilled water. I dont need to add any baking soda as the slurry is all ready there. Please do your research before comenting doubts this tech is here to stay many use it. look on line under HHO and see research it. please
I have read all that stuff
I resent that you people call me a Liar when you have no proof this does not work
I have the notes and the facts while you all have nothing but some figures on a paper from some left Wing professor that probably owns stock in Exxon or other co's. And has never sat in a car with one of these units and actual drove a couple hundred miles to see for them selves. This is a very poor way to make comparrisons and give us the readers your views with out good sound test facts like I have. You people have to try this and see for your self the others are wrong I have no reason to lie , i don't sell these things i don't make these things I buy them and use them and they work. thats all I can tell you this is worse than a Political debate with lies and word twisting.try it yourself and see I am correct in everything I said here. Join thousands of happy Motorists who are skinning the Arabs of bomb belt money, hehehehe
| How to run on hydrogen? | 1930u | Hotrodders' Lounge | 19 | 04-07-2013 08:32 PM |
| Saw earlier archives?? about hydrogen Burning in a car | rsfyj | Engine | 4 | 11-20-2011 09:21 PM |
| Hydrogen Burning Engine, no gas storage... | Cyberats | Hotrodders' Lounge | 101 | 01-29-2009 07:16 PM |
| Some hydrogen questions for those who know | Jmark | Engine | 33 | 08-26-2008 09:06 PM |
| hydrogen | silvertop | Introduce Yourself | 11 | 07-03-2008 09:26 PM |
