No mileage increas with the electric off. It realy bubles with the voltage going to i
Some times in cold weather I run with no energy to it and nothing happens no increases what so ever. but as soon as I apply 12 volts to it it starts to bubble and the vacume lines sucks it right up
The Wright brothers did fly, but 10 BTU is not hotter than 21k BTU.. Hydrogen in raw bottled form certinly does burn hotter, but not what is produced with the browns gas converters, given the advertised production figures.
I knew many out there used this device but didnt want the skeptics
I never said it couldn't work. It's not working by burning the hydrogen. could be as simple as throwing sensor values running it a little leaner than it should be. As long as it remains in range, there will be no code set...
Put it on a scanner with the setup, and then turn it off. see what sensor values change. you should see a change with the O2 sensor and possibly fuel trims if somthing's happening as you say it is. |
Well
taken Matt, but I don't care as long as it works for me. But I can burn the stuff coming out of my bottle I put a flash back bottle of water and bubble through that, Now if hydrogen can burn what happens to it when it gets to the combustion chamber? The same type bottle I use the guy on you tube burns a hole through a coke can with the same set up i have. This is the same stuff that sucks up my intake, What happens to it does it go out the exhaust pipe?? If the gas is flammable and it goes where a flame is it should burn, especially when its in a confined area and compressed.. Any way Matt this works for me and I not going to lose any sleep wondering how it works. I once had a hole in my roof it let water in I tried tar and all kinds of stuff to no avail. One day I put on an old Ct. License plate with 2 nails and it stayed there for 8 years and never leaked again, The point of the story is I never went up on the roof to see how and why the patch worked. All I cared was the leak stopped. I am not being wise but that's how I see things..
hydrogen fuel burning
I am starting to wonder if your not getting the temp. higher and the gas is evaporating before it gets into the chambers? Think about this for a minute...Lets just say, that with what your doing that it is becoming steam, before it enters the chamber...Your breaking down water, H2o...Since steam is hotter, could the possibility exist that the cylinder is becoming more dense? Now Smokey Yunick had it together when he did his 2 cylinder motor and put it into a Fiero...If you gas is vaporizing before it gets into the cylinder and not becoming droplets again, than you are doing basically the same as what Smokey did....Now, if this could be proved, or disproved, (gas totally vaporizing before it gets into the cylinder) then just maybe your on the right track...I am curious if the water splitting into steam, or Hydrogen, or somehow the gas is vaporizing before the charge gets into the cylinders...
http://www.hotrodders.com/forum/smok...ine-216191.htm I posted several articles here, if anyone wish's to browse... Good luck with your system.... |
| How to run on hydrogen? | 1930u | Hotrodders' Lounge | 19 | 04-07-2013 08:32 PM |
| Saw earlier archives?? about hydrogen Burning in a car | rsfyj | Engine | 4 | 11-20-2011 09:21 PM |
| Hydrogen Burning Engine, no gas storage... | Cyberats | Hotrodders' Lounge | 101 | 01-29-2009 07:16 PM |
| Some hydrogen questions for those who know | Jmark | Engine | 33 | 08-26-2008 09:06 PM |
| hydrogen | silvertop | Introduce Yourself | 11 | 07-03-2008 09:26 PM |
