anybody have a size for me ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2007, 11:01 AM
kc0kfg's Avatar
kc0kfg
My latest project a 50 chev 4 door needs a new drive train/running gear i was going to go with S-10 but have given some thought to 80's malibu or monty/cutlass "A" body's ?
What I am looking for is the track width and the over all wheelbase either from your own cars or if you know of a website with the measurements.
Thanks for your help Brian kc0kfg
Old 05-19-2007, 03:54 PM
Wiki Edits: 31
original frame, clipped with a camero suframe would do the same thing for you, but if you really want a new frame. 1977-1981 or so Imp/ caprice have been used. they have a simmilar track width, and 116" wheelbase ( 1" longer, you can deal with that, with some sheet metal work )
Old 05-19-2007, 04:04 PM
BOBCRMAN@aol.com's Avatar
"G" body frames also work well. Start with a four door and adjust wheelbase.
Old 06-09-2007, 10:43 PM
kc0kfg's Avatar
kc0kfg
any body have some sizes?
The imps are to wide length is no concern the s-10 and my 50 are around 60 inches but as you know s-10 are flat in the rear so i would have to do a kick-up or loose trunk space (not like there is much anyways)LOL.
how bout some real measurements from your G body's or other thoughts.
As I post this it may be a mute point Im going to the yard on Sunday I Hope to get some number's there
Thanks Brian kc0kfg
Old 06-09-2007, 11:00 PM
tfeverfred's Avatar
Last journal entry: Black Dahlia pics
Here is a chart I found for rearends. Maybe it will help.
http://www.quickperformance.com/Tech...us_measure.htm
Old 06-09-2007, 11:07 PM
kc0kfg's Avatar
kc0kfg
Wow talk about quick
Thanks that is just what I needed I'm sure others will find it helpful as well.
Brian kc0kfg
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 09:21 PM
'89 4.3L Cylinder Size Compared to SBC350 size (and gear drives) boneyard Buick Engine 10 04-10-2007 08:04 PM
exhaust size help SBC S-10 Engine 2 07-17-2005 12:22 PM
Bore size question 53LEDSLED Engine 5 05-12-2005 06:55 PM
S-10 tail pipe size catscan4free Engine 3 02-23-2004 02:34 PM
