Anybody install shoulder belts in older cars? ('59 Chevy in this case) - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2011, 06:09 PM
Motochris's Avatar
Picked up a '59 Chevy wagon and it needs seatbelts. I've seen a kit for a set with shoulder belts, just wondering if anybody has done that..and has some pics?
I'de like to see how it looks, and what was done to make a solid mount for the shoulder harness. Any vehicles remotely close would be good to look at, if it's a 59 chevy..all the better. Thanks for any info...
Old 06-24-2011, 06:29 PM
Motochris's Avatar
Looks like I'm answering my own questions...
Here's some installs on somewhat similiar cars that I just found-
55 Chevy install-- http://www.julianos.com/how2_55chev.html
56 Ford wagon install-- http://www.julianos.com/how2_3point56ford.html
55 Ford wagon in rear-- http://www.julianos.com/how2_3pt55ford.html
Old 06-24-2011, 08:34 PM
I put a set of three-point belts in my '33 coupe, fiberglass body with a solid 1" square tube internal bracing system. Juliano's instructions are first rate, as is their kit. Check out their How To section - http://www.julianos.com/how2.html
Old 06-25-2011, 08:42 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Let's put this in General Rodding Tech.
Dan
Old 06-25-2011, 11:48 AM
Motochris's Avatar
So you are happy with the kit and function?
Old 06-25-2011, 01:20 PM
Irelands child's Avatar
Here's another source for seat/shoulder belts: http://www.gotbelts.com/
(Not a lover of Juliano's and their products, but that's another story)
Dave W
Irelands child
Old 06-25-2011, 01:50 PM
Motochris's Avatar
Dave W
Wow..those guys have alot of color choices!
What is it you don't like about Juliano's products?
I first saw the shoulder belts at Impalas.com, but they are always backordered there. Started considering them on my LAST 59, but just ended up with lap belts on that one. I plan to keep this car for a good while..so I want a nice shoulder belt system.
Old 06-25-2011, 03:01 PM
It's a personal thing that dates back a few years and an NSRA show. His products are on my car regardless - steering wheel, door safety locks and insulation
Irelands child
Old 06-26-2011, 05:11 AM
brickyardboy's Avatar
We installed a set of Juliano's 3 point belts in my son's '56 Chevy wagon. They work well, but because of the bulky belt retractor, like most of these add ons, it doesn't look like it belongs in the car. You may want to check out Morris Concepts or some of the other quality belt providers for some different choices.
Old 06-26-2011, 05:45 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
what has been done is to cut the B pillar mount out of a donor and weld it to the B pillar on yours and do the same for the floor mounts of the seat belt then use the readily available replacement belts for a later GM car. This way looks factory to at least the casual observer.. Grab the factory Torx fasteners while you are at it..
Sam
Old 06-26-2011, 06:07 AM
Sorry, did not see your question/response. Yes, I was happy with the seat belt kit and instructions. As I pull out the belt retractor to latch the belt it will engage the inertia lock if I pull too quickly, but that's not an unusual thing, and I just needed to get used to their sensitivity.
Old 07-01-2011, 08:43 AM
This may or may not work, but look at 3rd generation camaros and firebirds (83-91. They use a different mounting system. Its been awhile since I looked but I seem to remember the retractor mount is on the floor as normal and then the 2nd mount is actually behind the seat in the ceiling and the belt is held in a 'keeper' attached to the side of the seat.
Introduce myself-installing 3-point shoulder belts newdeuce303 Introduce Yourself 3 11-10-2010 08:02 PM
Anyone install shoulder harness in rear of 41-48 Chevy? redsdad General Rodding Tech 5 08-14-2010 05:20 PM
Adding Shoulder belts to a classic car cruzinTLT Interior 14 06-04-2008 10:41 AM
Older Cars 400smb_s10 Engine 1 05-25-2007 09:20 PM
Shoulder belt install question. slider in wa Body - Exterior 5 01-22-2003 06:14 AM
