Anybody know of a good Harley site?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2008, 05:26 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
I know a few of you guys ride Harley's, So where are the good sites like hotrodders.com but for bikes? Any info would be great. Thanks.
Old 04-12-2008, 07:13 PM
powerrodsmike's Avatar
Wiki Edits: 161
These guys are no BS, no off topic stuff and are everything you'd expect from a bunch of bikers who live motorcycles.
The Horse
http://www.network54.com/Forum/47850/
Some really good fabricators and techs hang out there, and most seem to be from that end of the country...
You'll need to register with network 54 first, I don't know what all that will bring you...I didn't notice any greater amount of spam from registering.
The main focus is HD, and other V twin, but as alot of old school choppers were english bikes they talk about that stuff too.
I don't know of any HD forum that has the same friendly atmosphere like goes on around here. I don't get around much though.
If you use the search function on their site, select search by "match", instead of "date"...Date seems to always return me to the start.
Later, mikey
BE different....ACT normal.
Old 04-12-2008, 07:35 PM
weirdbeard's Avatar
1976 Ranchero GT
Ahh dang Mikey! Went and got a sportster against your advice... . I like it.. Its loud and leaky and loud. I was kinda hoping you would not see this post but you did... Thanks for the link. I have had this thing for like two days maybe and I have been choping the crap out of it! Motorcycles are way easier than 67 camaros!
Old 04-12-2008, 07:40 PM
Wiki Edits: 161
It's ok We used to say, sportsters are ok...until your friends see you.
hahahahahahahahahaahahah
2 wheels are fun no matter what.
Later, mikey
Old 04-12-2008, 07:44 PM
weirdbeard's Avatar
1976 Ranchero GT
HA HAHA! I am way to big for a sporty so people are going to think twice before they insult me I think! Its a catch 22 or something..
Old 04-12-2008, 07:52 PM
what year??? what motor??? i like sportys.
Old 04-12-2008, 07:56 PM
weirdbeard's Avatar
1976 Ranchero GT
Its an 883 for now. 2000 and yellow! I am on that right now! Yellow! Why?
Old 04-12-2008, 08:13 PM
i could tell you how to make that faster than greased snake snot!!!!
Old 04-12-2008, 08:19 PM
Wiki Edits: 161
Why am I thinking of monkeys....and footballs.......hmmmmm
I just don't know...
Let me think about it for a while...
later, mikey
Old 04-12-2008, 08:40 PM
weirdbeard's Avatar
1976 Ranchero GT
later, mikey
I really don't know but it sounds funny! Probably at my expense
I would also like to know how to make this faster than greased snake mucus or like you said Techron. . I am a hot rodder despite the fact I bought a sporty..
Old 04-12-2008, 10:09 PM
don't feel bad wierdbeard, i've had both sportsters and full size harleys and for the type of riding i do (around town, errands, short trips-like under 200 miles each way) i actually prefer the sportster. i also use my bike almost everyday all year around, if you have saddlebags, a short sissybar and some bungies you can pack a lot of stuff.
here is the hot setup: i got this from a V&H tech i know and it works:
1-forget the screaming eagle stuff, go with buell racing stuff.
2-first you are going to incease displacement to 1200, order 2 buell 16871-99Y barrels-they bolt right on to the 883.
3-order 2 buell 22676-98Y high compression piston and ring sets.
4-order 1 each buell high flow racing head-front 16797-98Y -rear 16827-98YB, these are the thunder heads.
5-a set of andrews cams, as i recall they are the #2 set but i don't have the part number handy.
6-crane dual-fire ignition and coil package, don't remember the part #.
7-carb jets , i had to go up 2 sizes on the low speed jet and ended up with a 200 main jet (165-170 is stock and yes there is such a thing as a 200 main jet, most people dont know it and it has to be special ordered.
the nice thing is all these parts can be ordered at your local HD dealer and some are a little cheaper than the screaming eagle crap.
MODS:
1-get rid of all the smog crap,look around the frame under the front of the rear swingarm.
2-take a hole saw and swiss cheese the plastic air cleaner base on the outside of the filter-this is a major breathing restriction.
3-remove the baffels from inside the exhaust pipes-this is a major breathing restriction. it won't be that loud under normal driving conditions because the engine has so much power you hardly have to give it any throttle.
4-polish the combustion chambers and piston tops, a smoother surface has less area to absorb heat and will resist detonation, the pistons have a CR way north of 10-1.
5-rejet carb and go with spark plugs 1 step colder than what a 1200 cc would take.
cliffnotes-
don't forget to bolt the front head support to the head first, the head is so big you won't get it on after installing the head (ask me how i know--> )
the 883s are actually geared lower than the 1200s so this helps acceleration even more.
under normal driving conditions you probably won't move the throttle more than about 1/8 inch. that took some getting used to-you don't actually move the throttle to go faster, you just think about it-->
buy a GOOD battery, you'll need it.
i did mine at 20,000 about 4 years ago and am approaching 35,000 and it has been totally reliable and runs like the day i started it and i have enough power to beat everything except a few BIG INCH S&S motors.
have fun and hang on....
Old 04-13-2008, 12:10 AM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Funny you mention S&S Cycle. They had their original plant within 40 minutes of where I grew up. Had a nice plant tour about 15 years back, lots of cool stuff to drool over.
In a while, Chet.
Old 04-13-2008, 12:26 AM
Wiki Edits: 161
It's too bad that S&S is making crappy parts now too...2 years ago I bought a set of brand new S&S heads from a friend who has been an S&S dealer since the 70's...He ordered them from the factory.
They lasted about 2 weeks before they burnt both exhaust valves. Upon inspection I found the margins and seats were ground so thin at the factory that the edges burnt back...S&S told me that they would take them back for a warrantee, but it would take 8-10 weeks and they would inspect and repair as a warrantee at their discretion, and if they felt it was my fault, I'd be sent a bill for the repair. My friend said they rarely find themselves at fault.
I took them to the local guy ...300.00 dollar valve job added to a set of two week old 1100.00 set of heads.
I know the valves weren't too tight...mine is a kick only, solid lifter bike, they don't start at all if the valves are too tight.
I'll bet it was a cool tour though...
later, mikey
Old 04-13-2008, 12:34 AM
Sportsters are considered GIRLS bikes around here ...
I had a couple Sportsters in my life ... I bought my first one ( a 1957 ) in 1964. Bought another one ( 1970 ) in 1970. In 1971 I bought one of the first SuperGlides ... ( white ) and have never went back to Sportsters.
The white Deuce HD above is actually my second Deuce HD ... I had a Concord Purple 2001 ... bought new in Dec 2000. Rode it 3700 miles in 6 months and then had a heart attack. Sold it ... could not ride it ... but I finally got better 3 years later, then I bought my 2004 Deuce and only have 4200 miles on it total ... slowed down a good bit.
This site is for two wheel fun ...
http://www.jockeyjournal.com/forum/index.php
Be aware that profanity is allowed and it may be considered a little rough ... depending on how easily you get offended.
Old 04-13-2008, 01:04 AM
Wiki Edits: 161
Jockey journal just got a new member.
Why does that place look familiar ?....
hahahahahha
Later, mikey
Good Grounding can make a difference ep33510 Electrical 2 12-07-2005 07:42 PM
new to site bigblockcrazy Introduce Yourself 2 11-16-2005 03:53 PM
whats a good site for free music downloads?? rubberwoman2003 Hotrodders' Lounge 23 11-30-2003 07:15 AM
Find a good LT1 site Ciaopeeps Engine 2 11-01-2003 09:09 AM
350 and good gas milage and a combo HELP changer01 Engine 7 09-22-2003 11:05 PM
