Anybody know what this box is for? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2013, 09:28 PM
Took the dash out of my 77 Ford F100 shortbox today. Found this electrical component on the drivers side up in by the parking brake release. I have no idea what it does. Doesn't seem to be anyplace to plug it in. This truck has been screwed with a lot over the last 35 years. I know it was a standard 4 speed at one time due to the hole in the hump. Anybody recognize it? Do I need it.
ID:	70318   Click image for larger version
Old 01-06-2013, 06:08 AM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
Controller for delay wipers?
Old 01-06-2013, 06:18 AM
carolinacustoms's Avatar
Automotive Extraordinaire
The part number on the box makes it a wiper realy. It is supposed to plug between the switch and wiper motor. Im not sure it is a "delay" or not though.
Old 01-06-2013, 12:56 PM
OK. Thanks guys. So I guess at one time the truck had delay wipers. I wonder if I can hook it back up, if it's any good. Does it take a special motor for delay wipers?
Old 01-06-2013, 05:40 PM
I'm not so sure it is a wiper delay. It may be though. The part number comes back to a wiper relay. Do you wipers work now? If so plug the relay in line and see if anything changes.
Old 01-06-2013, 05:52 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I worked as a Ford partsman from 1978 to 1992, and agree with what cucumber has told you ... "17C476" was the ford basic number for a wiper delay module. (NAPA and Blue Streak DO call them a "relay" though)
If you go to Bluestreak's Online Catalog and then click on the cross-reference tab. Enter "17C476" into the text-box, and then click on the "contains" selection and press [Search]
The way to tell for sure is by the look of the switch. The "interval wiper" switch had an addition external wire lead on it.
Old 01-06-2013, 07:20 PM
Thanks guys,
The dash is out now, but when the truck was running the wipers worked fine, but only 2 speed, and I think the switch is just a 2 speed. As I said the truck has been screwed with over the years and maybe originally it had delay wipers, but not when I got it. There's nowhere to actually plug this thing in. Wires go directly from the wiper motor to the switch.
steering gear box 55 chevy(manual box) 55 Bullit Suspension - Brakes - Steering 3 11-21-2010 01:35 PM
Vega Box or Reverse Corvair Box? Ltlgto Suspension - Brakes - Steering 9 04-24-2008 05:02 PM
To Box or Not to Box - That is the question H2Os50 Suspension - Brakes - Steering 7 06-16-2005 07:39 AM
ford/chevy box new box demetions? 56-Dodge Body - Exterior 2 01-01-2004 09:06 AM
HELP 1959 chevy box swap to newer box style big jer Body - Exterior 1 10-07-2002 12:37 PM
