Anybody know what heads these are? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2009, 11:25 PM
Can anyone identify this head casting symbol?
On my buddy's 400. They have center bolt valve covers.
Old 08-30-2009, 02:20 AM
DoubleVision's Avatar
They appear to be late 80`s swirl port smogger heads. However, I would pop the valve cover and get the casting numbers, you only need the last 3 numbers, you can look up what they are here:
http://www.mortec.com/castnum.htm
Old 08-30-2009, 01:46 PM
This is my buddy's car, he won't let me pull a valve cover. I'm trying to see what he's got.
Old 08-30-2009, 01:51 PM
They appear to be 193 castings which are swirl port heads. These are the poorest flowing SBC heads ever made.
Old 08-30-2009, 04:30 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Easiest way to tell:
If you have 12 intake bolts and they all go straight into the head, its a one-year-only 1986 head that was pretty low-flow. If the center four bolts on the intake are at a different angle than the rest, its a TBI swirl port head and its (no offense) pathetic for anything other than a stock 305 or 350 that only needs to rev to 4500 at most. Supplying a 400 with those little restrictive ports probably limits the power potential to about 3900 rpms.... which is fine if that's his goal.
If the intake has only 8 bolts and they all point straight down toward the ground, its a Vortec head and its the single best-flowing factory production head that chevy ever made for the small block and it should support that 400 to about 5000 RPM with great power and torque potential.
Old 08-30-2009, 04:52 PM
As DV, said looks like 193 castings.
sam-missle
Old 09-01-2009, 11:34 AM
Thank you all for the help!!!
The center two intake bolts are at a slightly different angle pointing more towards the ground than the rest. Guess this guy has a really mismatched combo...
Isky 201304 (304/.525)
Weiand Stealth intake
Holley 770 street avenger
And these piece of junk heads.
Preciate it yall.
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 04:50 PM
Which Heads to use? Mike_82 Engine 9 03-05-2009 11:32 PM
sbc heads shieldbreaker Engine 5 08-27-2005 09:12 PM
Heads and Intake combo black66 Engine 4 07-24-2005 12:33 AM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 02:16 PM
