Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - > Anybody put a 351W into a '59 Galaxie?
Old 10-11-2003, 01:03 PM
woodz428's Avatar
woodz428 woodz428 is offline
Troll Hunter
You can use'63-'64 Galaxie 289 motor mounts and the trans mount on the trans should work. If the original trans was a Cast Iron Cruiso you can probaly use the stock crossmember with little modification, the 2spd Fordomatic one will probably require some mods. I just did one in a '59 about a year and a half ago and it was a fairly easy swap. The frames from '57 -'64 are virtually the same.
