anybody sprayed "as cast" paint on an intake? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2004, 12:54 PM
bullheimer's Avatar
NEVER use credit cards!
howz it performing?
Old 04-27-2004, 01:19 PM
BOBCRMAN@aol.com's Avatar
I usually give my cleaned intakes a light mist coat of "cast blast". Especially the factory castings that have porosity and color issues. It looks better than a tank or detergent cleaned intake and is near impossible to detect on a blasted intake. It resists fingerprints better and clearcoats well. Fuel will make it dissolve and run tho.
Old 04-27-2004, 01:24 PM
bullheimer's Avatar
well, bob, i was mainly concerned about it's ability to take heat. i havent seen a high temp version.
BUT... if gas disolves it. i guess that's the end of this story glad i didnt paint it yet.
Old 04-27-2004, 03:50 PM
club327's Avatar
Well I was thinking about doing the same as I've got some VHT exhaust 'as cast' finish paint left over. Looks great and will look good on the intake as well. Most paints should be fine on the intake, but you won't go wrong with the VHT stuff, and they do make the paint your after that's 1500 degree F rated.
Old 04-27-2004, 03:59 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
I think bob is talking about a different product that you are. I have used the duplicolor engine paint on alot of stuff and it will even withstand brake fluid for short periods. If you wipe it off it is just fine. I use it for alot of small chassis parts and brackets.
Chris
Old 04-27-2004, 04:15 PM
club327's Avatar
Thanks for that. Who makes this cast paint?
Old 04-27-2004, 08:02 PM
TurboS10's Avatar
Wiki Edits: 2
Duplicolor makes cast iron and cast aluminum high temp engine paint.
Chris
Old 04-28-2004, 09:03 PM
bullheimer's Avatar
reading the label on this duplicolor can, which is what i've been using, i don't know what are you using Bob? it says: rebuilders CAST FINISH 500 degree coating, resists oil, brake fluid and gasoline. sounds good, hoping Bob didnt use THIS stuff. however, as we all know, gas resistant (or water resistant) doesn't mean gas or water PROOF.
