Anybody use Posies rear leafs on 41-48 ford? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2007, 04:10 PM
I was considering a Posies rear parallel spring kit for the rear. They say that the springs mount inside the frame rails and clear the gas tank. I can't visualize how this would fit. Posies didn't have any installed pictures of the frame. I was hoping somebody here would. Also, If anybody has used them how is the ride?
Old 04-27-2007, 01:34 PM
deliveryman's Avatar
Here are some pictures of the Posies kit I put in my '46 Ford sedan delivery. The first is the stock frame and the others show the installation. The pictures are old as this was done some time ago. Unfortunately, I don't know how the ride is as some projects just don't seem to get finished. The guy that installed the kit was impressed with the quality and he built frames for off road race trucks.
Name:	46 FRAME 1.jpg
ID:	20784   Click image for larger version
Name:	46 FRAME 2.jpg
ID:	20785   Click image for larger version
Name:	46 FRAME 3.jpg
ID:	20786   Click image for larger version
Name:	46 FRAME  4.jpg
Old 04-27-2007, 07:50 PM
Thanks, that helps some. So the leafs appear not be parallel, right?
Old 04-28-2007, 12:58 AM
I got a 41 in the garage with the posey suspension on the
rear, didn't get down and look at it too well
but will do so tomorrow
couple of pic's I don't know if you can tell the ride height
or not, can try to get better pic's of ride height if you want
ID:	20821   Click image for larger version
ID:	20822   Click image for larger version
Old 04-28-2007, 01:15 AM
I think it sits well
as soon as i get a little time
the body is coming of the frame
and will see even better
Old 04-28-2007, 06:50 AM
I used Posies springs on a 37 Ford and the installation went well and I thought the ride was very good.
Bob
Old 04-28-2007, 09:59 AM
Fabricator, I like you plan on redoing my car. I am making plans now on what direction to go with suspension. The front has a Camaro stub. The rear has some unidentified leafs. I was also thinking of a Wonderbar type suspension like Fatman makes for Mustangs. If the Posies kit is really that good it would save alot of fab time. More pic of ride height would be great. My car is just passable now, I want it lower in the rear. Thanks for the input!
Old 04-28-2007, 10:03 AM
No, they are not parallel. Just went out to garage and measured. They angle in 4 inches. Hope this helps.
Old 04-30-2007, 02:09 PM
That helps alot. Now I see how it all fits together.
Ford rear main seal question. el pollo Engine 3 07-15-2006 09:12 AM
1945 ford p/u rear leafs,to keep or not to keep biglee550 Suspension - Brakes - Steering 8 04-25-2005 07:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
Converting Jag rear end to Ford 9" Jag Daddy Transmission - Rearend 5 12-25-2003 02:47 PM
