Anybody used central pnuematic compressor pum - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2009, 08:23 PM
I bought a 3 hp air compressor pump from harber freight.When it pumps between 75-134 psi it blows oil out of vent.Alot of oil.I went and exchanged for another one still does the same thing.Anybody used these pumps are they all bad? give me some help tired if going back to tulsa. ps I know these pumps are not that good.But they should be alright when they are new. thanks proge
Old 08-26-2009, 08:24 PM
cranky1's Avatar
Just stuck
Welcome to Chinaland.....
Old 08-26-2009, 10:12 PM
Barn Owl's Avatar
I will not by anything that has a motor or hydraulics from HF. My sand blaster works fine but there is nothing to it just a square box a gun and a hose. I have had to take too many things back to chance it anymore.
Old 08-27-2009, 07:53 AM
Don't rule out everything just because it comes from HF, they also carry Puma brand compressors and you can believe this or not but the large US General compressors are made in USA, even the tank is made in Virginia! I have no personal experience with the US General other than to look at them in the stores but for the money they look like a darn good buy, they have A.O. Smith electrics and some of them actually have Baldor motors.
Now back to the topic, I have installed a couple of the 5 HP V-type pumps and they work good but at least two of the guys here have bought the same pump you have and were not satisfied at all. Have you eliminated all other possibilities? How about the backflow valve in the tank? How do you have the unloader valve plumbed?
Old 08-27-2009, 08:09 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I have one of those installed and it works fine,,will it replace a quincy well no but for 99 dollars it works..
Sam
Old 08-27-2009, 09:58 AM
I would think that for enough pump blow-by to cause that much crankcase pressure would require a major fault such as a hole in a piston or maybe someone even forgot to install rings! It would be very strange for two pumps to have the same major flaw but I guess anything is possible and if they were both built the same day,,,,,well who knows what might happen? Still every other possibility should be eliminated before blaming the pumps, which very well may be at fault, so look the set up over and see if there is any other possible way for pressure to be leaking from the tank or supply lines into the crankcase. My first question would be, does the oil/air continue to leak for a while even after the pump shuts down? If so then for how long?
Old 08-27-2009, 03:32 PM
I am going tp put in a new check valve
I have ordered a new check valve for air tank.Somebody said to take air line from tank and it should hold pressure.It does.I dont know if a lon break in period is required.I have put in about 2 quarts oil as it gets low. let me know what you think thanks proge
Old 08-27-2009, 04:32 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
You sure your not just over filling the pump? Two quarts seems like a lot.
Old 08-27-2009, 05:03 PM
And then some! Does that pump have a sight glass or dipstick? If you took the line loose from the pump to the tank with the tank pressurized and it did not leak air then you do not need a new check valve. Also if the leak stops as soon as the pump stops (that is no oil or air leaking out) then it should be one of two things, either the pump actually does have that much blow-by or it is over full.
Old 08-27-2009, 07:45 PM
pump has a sight glass
the pump has a sight glass and I have filled it to the center of the glass which is what instructions say.It does not say how much oil to use.It took over a quart to fill it. thanks proge
Old 08-28-2009, 07:20 AM
I sure thought we had found the problem but it sounds as if the oil level is correct so that's not it. If air and/or oil continues to leak out for more than a few seconds after the pump stops then it is air pressure leaking into the crankcase from the tank, if however it continues to leak for only a couple of seconds or so after the pump stops then it is most likely blow-by from the pistons. If it stops instantly and no air is leaking either when running or after it stops then it is some sort of mechanical malfunction or simply too much oil in the crankcase but I think we have ruled out the oil level being the problem. Describe the leak in more detail, does it leak air along with the oil? Does it continue to leak either oil or air for a time after the pump stops? If so for how long?
Old 08-28-2009, 10:07 AM
pump runs normaly to about 75 lbs
Then it starts to spit oil out of vent and the more pressure there is untill it spews oil out.I have got a long hose with a funnel on the end and run it.Only way I can keep oil in it.Real soutnern engineering.But at least I can keep oil in it.I may just open tank valve and watch and let run for an hour. thanks proge
Old 08-28-2009, 02:44 PM
There should be a bleed valve in the line from the compressor to the tank and a one way valve where the line goes into the tank. When the compressor stops, the bleed empties the line and the one-way stops back flow from the tank, these valves are probably combined in one package. This prevents back-flow into the crankcase and permits the motor to restart without the load of compressed air against the pistons. Listen for their operation, when the pressure switch shuts off the motor, you should hear the sound of vented air from the exhaust tube.
Some compressors are just messy about crankcase oil venting, even my old Kellogg American needs a length of hose and an old coffee can to catch the puke.
Bogie
Replacement for the HF43430 gun 406 bug Body - Exterior 38 04-01-2009 07:52 AM
80 Camaro Central Wisconsin hardsixstring Introduce Yourself 1 05-23-2006 09:47 AM
Central air question?? HemmiGremmie Hotrodders' Lounge 8 08-23-2005 03:49 PM
Central Vac System for Shed 49 T&C Garage - Tools 3 09-16-2004 01:58 AM
