Anybody used Speedway Fiberglass? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2010, 05:02 PM
327NUT's Avatar
Here's my problem, 4 yrs ago I bought a complete set of Brookeville steel fenders, running boards etc. for my '32 Victoria build. As luck would have it "things" got in the way and I also spent a lot of time on the chassis and engine.
Now I'm starting on the body and find out the front fenders WEREN"T made by Brookeville but by some outfit named "Funk's wh o are out of bizz and they don't fit worth a damn. I called Brookeville this morn and they basically said sorry, nothing they can do....but if you send us $1200 + $150 shipping we'll send you a new in house made set of front fenders!! Yea, right.
So due to money, I'm going to have to go with glass fenders. The Wescott's are $730 + shipping but the Speedway's are $500. Has anyone seen or used them, don't mind a little body work, figure on that aspect anyway. Just don't want cheap stuff. By the way the rear fenders, frame horn covers and running boards made by Brookeville fit perfect....thanks, Dave
Old 05-17-2010, 07:40 PM
302 Z28's Avatar
Wescott's quality is unquestionable, I would not be so sure about Speedway as I am sure they do not make them.
Vince
Old 05-17-2010, 09:34 PM
327NUT's Avatar
Vince...I called Speedway today before posting and actually they are made in house. They have a guy that has been there for a long time and makes all their fenders and small parts. Yes I know Wescott's is top notch stuff, it ought to be for the price they charge.
Old 05-17-2010, 10:02 PM
powerrodsmike's Avatar
Wiki Edits: 161
I've used both, Speedway does make their own, but you get what you pay for...Resin rich, heavy and wavy..You can do bodywork on them, but the waves will come back. Wescott's uses a better resin, and hand lays them so they are not overly resin rich... (not that you can't make decent parts with a chopper gun, but most companies don't take the time.)
Later, mikey
BE different....ACT normal.
Old 05-18-2010, 01:34 AM
327NUT's Avatar
Thank you, thats the info I was looking for.
Old 05-18-2010, 05:52 AM
The steel ones are that bad that you can't massage them into fitment? wow!
Old 05-18-2010, 09:25 AM
boatbob2
Speedway Fiberglass
Their glass is chopper gun lay-up,too thick,poor trimming,lines dont line up too good. but,acceptable product,if you dont mind some extra work.
Thining fiberglass resin to spray. Is it possible? smithkustoms Body - Exterior 17 01-08-2010 08:15 AM
fiberglass roof ratrodnova Body - Exterior 18 09-12-2009 06:29 PM
Sanding the *%^$&# primer all off the fiberglass parts Ripped Body - Exterior 7 09-01-2007 07:56 PM
fiberglass to fiberglass scoop bluebu Body - Exterior 62 06-23-2005 05:15 PM
Fiberglass help for novice tyman00 Body - Exterior 1 10-20-2004 12:36 AM
