Anyoldchevy, more pictures!
Hey Anyoldchevy:
Got any more photos? Great looking car. What kind of front-end is that? Did you do a full clip from something? I looked all through your journal and couldn't find the details on the front-end. BTW, I agree with your wife; you're doing fine work and don't need to let a body shop maybe mess it up. Wish I could straighten metal like that. |
Yup, been following your journal for quite a while now. You're coming along fine, I like the photoshop.
http://www.hotrodders.com/forum/jour...%20side%20rear Mike |
more photos
Hey thanks for the compliments. Im not use to that. Im having a lot of fun building this 48. The front end is stock except for the disc brakes, and i cut 1 coil out of the springs which dropped it 2 inches. Like i said this is a low buck rod.
MrWood are you Anynoldchevy???
Mike |
BTW, that '41 Chrysler and '17 T are beautiful, IMO! |
mrwood
Nightfire, yes Mrwood is anyoldchevy. Also grouch, i think you can get the same disc setup for your 49 as i have on my 48 chevy.It uses your stock spindles, and is a real nice setup. Now i may be wrong on this, as 49 may be different.
brakes
grouch, i got my brake kit from Master Power Brakes. The complete kit was about $380.00, they also sell drop spindles if you want things a bit lower.
Thanks, I'll check those out. If I can't get the suspension I want under it, at least it will stop better.
It looks like there was a lot of woodworking on that 'T'. That's something I can understand better than sheet metal. It follows some kind of logic; you heat it, it burns. Body panels don't make any sense when you heat them. They pop first one way then the other and can't decide if they want to shrink or expand. Didn't you mention torching out some lead from that '48? |
lead
I dont think i said anything about lead. I did have some problems sanding where the original lead was used to fill some seams. I could not get it smooth enough so i had to use some spot filler over it.
You're right, you didn't mention lead. I went back through the whole thing just to see. Somewhere in the journals I remember running across a 40's GM product where the guy torched about 2 pounds of lead out of the body. It stuck in my head because the photo of the blotches looked just like some on my '49. It made me wonder how in the world you could torch the lead out without warping the steel.
What kind of primer is that? epoxy? lacquer? Sitting there in gray, that old humpback really reminds me of the first car I ever remember riding in with my dad. It was gray outside and in. The only real color to the interior were the knobs, in that sort of yellowed ivory color, and the gauges with their almost black faces. I like those Caddy tail lights and the twin antenna idea. |
| Recent Hotrodders' Lounge posts with photos |
| Posting pictures | lluciano77 | Hotrodders' Lounge | 3 | 08-21-2004 08:15 PM |
| Help with posting pictures,....PLEASE? | OddRodder | General Rodding Tech | 18 | 02-18-2004 10:17 PM |
| Can't Down load pictures | tm454 | Hotrodders Site Suggestions and Help | 2 | 10-28-2003 06:45 PM |
| Local car and engine pictures for you guys | nicefrog | Engine | 10 | 01-06-2003 03:25 PM |
| Album Pictures | Croz | Hotrodders' Lounge | 3 | 08-03-2002 12:57 PM |
