Anyone Airbrush? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2007, 03:52 PM
Anyone Airbrush?
I took some lessons a few years ago and got into cartooning and such then not thinking left paint on the needle and messed it up. I use an Iwata HP-C duel position gravity feed (jeesh say that ten times fast). Does anyone else do air brush art? And possibly know where I can get a new needle and also where I can find a quiet electric air compressor?
Thanks,
-Keith
Old 02-20-2007, 07:00 AM
FordMan1951's Avatar
Ford Man to the bone!!!
I used to do a little back in the day. I had a cheap setup and let it get gummed up too. Trashed it years ago.
Try asking in the "Garage - Tools" forum... you'll get a faster answer.
Old 02-20-2007, 03:22 PM
King of my Man-cave.
Thanks,
-Keith
Look at some of the modeling (airplane, car, etc.) websites and magazines. There are many compressors specifically designed for airbrush use. You can also find airbrush dealers that my be able to help you look for parts.
tom
Old 02-20-2007, 06:35 PM
Airbrush pro
It's very important that you keep the airbrush clean by running solvent through it at regular intervals. Get a little plastic spray bottle or those mini plastic 1 oz. bottles with the snap-open tops so you can measure out drops and keep it clean between sprays. The airbrush will only work as a precision instrument if you keep it super-clean for consistency of operation. If you're using water-based, water or a little alcohol would be your solvent, or a dedicated airbrush cleaner. Don't soak your airbrush in solvent because paint thinner or reducer will eat up the little o-rings and ruin it. Run thinner through it to loosen up the needle, but if it is still jammed remove the air cap assembly and firmly pull it out or push it through without bending it. Bearair or Coast Airbrush are great for supplies, like new needles, compressors and whatnot. Let me know if you have any other questions.
ID:	18704   Click image for larger version
Old 02-21-2007, 12:44 AM
I just got one for chrismas but im holding off on using it until i get a presure reg (one seperate from my big compressor) so i dont blow it up
Old 02-21-2007, 06:54 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Get a can of carb cleaner. DO NOT let it get on plastic pieces, but thats the ticket for cleaning dried up paint. I don't know of anything that works better. Flush it when you are done.
Old 02-23-2007, 09:55 PM
THX_138's Avatar
30 Ford 5 Window
Castrol "Super Clean" will do the trick if you soak it in it for a while... won't hurt any of your o-rings or plastics either.
A soak in "Pine-Sol" works too.
Old 03-18-2007, 12:03 PM
davedeltadog's Avatar
all the right advice
Agila1 gave you the info you need, use a good cleaner all the time, I buy from Bearair.com, I did this Model A mail box last weekend, my second one, took a class last year,but don't do much, it's fun when I find the time
Old 03-23-2007, 09:37 PM
inkwork's Avatar
If you have access to an ultrasonic cleaner, for jewelry or the ones used for old repeadograph pens, you can get the stubborn crap out of the hard to reach places. I had forgotten paint in my old badger for over ten years, and that's how I cleaned it. Then my wife accidentally threw both of them away. Now I have a new Iwata HP.
ink
Airbrush artwork discussion and samples of eagle and pin-up aguila1 Hot Rod Art 14 09-23-2006 08:04 AM
Airbrush for beginers - advice please Steve UK Body - Exterior 6 09-04-2005 01:11 PM
Airbrush Paint AdamZx23 Body - Exterior 16 02-20-2005 08:37 PM
airbrush recomendation raymrajak Body - Exterior 11 12-29-2004 08:53 AM
Help with project LadyMud Body - Exterior 0 07-08-2003 08:21 PM
