Anyone done a clutch on a Ford Ranger? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2010, 09:29 PM
Hey guys, my dads 2002 Ford Ranger 2.3L 4 cylinder has a leaking slave cylinder that needs replacing. Simple enough, however, the slave cylinder is internal meaning it rides on the input shaft (another brilliant idea of Ford). So to replace this I will be removing the entire transmission, and while I'm in there why not replace the clutch since it has 90,000km on it. Questions and concerns I have. What special tools are needed, I have read that a special Ford tool must be used to remove the hydraulic line from the old slave cylinder since they use a special "quick connect" coupling, is this true? Also if there is any other special precautions I need to know before tearing into it please enlighten me. I plan on doing this friday so I have a couple days to read up and gather the parts and supplies necessary to replace the slave cylinder and clutch assembly.
Thanks,
Keith
Old 07-07-2010, 01:16 AM
Wiki Edits: 31
yes they do use a special quick connect.. there not a hard thing to replace, but the line is expensive if you mess it up, and they can be diffacult to bleed out..
check with the dealer tho.. slave cylinders on those trucks in that year were recalled. if the recall is outstanding, then it might be able to be fixed free
Old 07-07-2010, 04:59 AM
tnsmith10's Avatar
when will it rain???
Thanks,
Keith
there is a "special" tool for removing the hydraulic line from the slave but, a flat head screwdriver will work as well since thats what i used for a good couple years before buying the tool. a little tip on the line removal, push the line in towards the slave when pushing the plastic release tab in. it will help take the load off of the tangs inside that retain the line.
also when it comes to the internal slave, when done with the installation of the trans, and ready to bleed the slave, its easiest to either back bleed it or use a hand held vacuum pump to evacuate the air that gets trapped inside of the top of the slave as the bleeder is more or less located about 1/2 way up.
other than that, with it being a simple 4 cylinder, theres no need to remove the exhaust, and should be a fairly simple R&R.
Old 07-08-2010, 08:48 PM
Thanks for the replies guys, however, I can't seem to find anything on the net that indicates there was a recall for the slave cylinder of 2002 ford rangers. Do you have any info or links on the web supporting this?
Thanks,
Keith
Old 07-09-2010, 06:26 AM
302 Z28's Avatar
Thanks,
Keith
Check with your local Ford dealer, just bring them the VIN number and say nothing about what needs to be fixed.
Vince
Old 07-09-2010, 05:59 PM
tnsmith10's Avatar
Thanks,
Keith
well i wont say that theres not a recall, because i havent looked, but since the clutch system that theyre using in the 02 ranger you own is the same design that they have used for over 20 years now and i havent seen a tsb on it yet except for bleeding precautions and procedures, id say its a safe bet its just normal failure which theyve been prone to.
i will say though, i do like vinces idea of going to the dealer anyway just to see.
ya never know. gl
Old 07-10-2010, 01:10 AM
Wiki Edits: 31
I know theres a TSB on the "squeaky slave cylinder" which eventually transforms into an inop clutch.. I'm pretty sure there is a recall on them for the 2001-2003 model years, altho 2001-2007 have all had reports of the squeaky slave..
Ford 302ci In A 1984 Ranger 4X4? izzymiddleton Hotrodders' Lounge 26 12-10-2014 01:55 PM
1986 Ford Ranger, wont run. hybridste Engine 10 07-10-2013 08:00 PM
ford bronco hyd clutch conversion. Jared Transmission - Rearend 2 11-07-2007 04:00 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Ford Ranger V8 Conversion izzymiddleton Hotrodders' Lounge 13 11-14-2005 11:23 PM
