anyone ever doby drop a 53-56 ford f100? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2006, 11:59 AM
anyone ever body drop a 53-56 ford f100?
im thinking of doing it and wondered if anyone has any helpful suggestions or photos of it being done
Old 02-27-2006, 03:55 PM
meant "body" drop
meant body drop
Old 02-27-2006, 06:45 PM
By dropping a body, do you mean channeling over the frame? Channeling a body on an F-100 sound easy...It's not. First you cut out the floor, then cut the rear of the cab so the body can be lowered, then reposition the body mounts. You may have to cut the firewall........Then comes the bed....Then the radiator supports, and inner fenders....need I go on? What would be a lot less work would be to lower the entire frame. To lower the front use an Volare or Cordoba IFS, it's almost a bolt on. With that you'll get power steering and disc brakes. You can adjust the height and ride through the torsion bars. The rear can be done through reversed eye springs along with other methods. If you want to stay all Ford, then check out these places for kits:
www.LMCtruck.com
www.classicperform.com
I did mine a little different. I swapped out my frame completely. I used an S-10 frame under my 52 F-1. This gave me IFS, power disc brakes/steering at a fraction of the cost of aftermarket. If you're interested, I have a website about the swap:
www.geocities.com/lakota_circle_dancer/swap1
headers for 53 ford f-100 pocket Engine 1 02-10-2003 02:41 PM
53 ford bed/box tgregoire Body - Exterior 0 08-08-2002 06:37 AM
53 ford f100 rear window tgregoire Body - Exterior 1 07-16-2002 06:20 PM
suicide doors on a 53 ford f100 tgregoire Body - Exterior 0 07-16-2002 09:18 AM
Swap small block chev into 53 ford Kasper Engine 11 02-07-2002 08:19 PM
