anyone ever install kugel 90 degree brake unit? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2004, 08:20 AM
New Member
Has anyone ever installed something like this? Or even have any other pictures of it?
Old 06-01-2004, 05:05 AM
deuce_454's Avatar
i have made my own 90 degree setup, i found the kugel unit abit flimsy and to big for mt application, mine is setup for hydraboost...
Old 06-01-2004, 08:24 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
look at some of the early dodge vans they used this same set up for years & w/PB's too....joe
Old 06-01-2004, 06:58 PM
New Member
I want to make my own but Im not sure how to start...do you have any pics? Id like to just run a 8" booster and remote fill master cyl under the dash if possible.
how early? can u explain exactly what power boost does and what are its advantages/disadvantage?
thank you
Jim
Old 06-01-2004, 08:56 PM
Wiki Edits: 5
mid 70's up used them, cant tell ya to what year cause i ain't a dodge guy, but i know they used them cause a friend had a few. & the "PB" means POWER BRAKES & the advantage is less pressure on the pedal to stop the car or truck.......joe
Old 06-02-2004, 02:03 AM
deuce_454's Avatar
it isnt that hard, but youll need access to a lathe or someone who can turn a couple of things (about 1/2 hour of work..) and some means of cutting 3/16 plate. PM me and ill send you in some sketches of what ive done
Old 06-02-2004, 10:15 AM
Forget about those big *** boosters......... go to www.hydroboost.com They make a booster that runs off of the power steering pump....... You can also get in touch with Bob over at Par Brake Svc. 562-907-7712. They offer a kit built by Bosch that does the same thing.
Old 06-02-2004, 02:15 PM
deuce_454's Avatar
that is exactly what i installed, except i took mine from an astrovan in a junkyard and it set me back 50 bucks...
Old 06-02-2004, 06:34 PM
New Member
doh i feel dumb...power brakes lol.
Old 06-03-2004, 07:12 AM
Wiki Edits: 5
it'll be ok just go take your meds & take a nap, then when ya wake up you will realize that it was all just a bad dream ....joe
Old 06-05-2004, 06:09 AM
New Member
well im going to head to the junkyard today and see if i can find any 70s+ dodge vans with that setup.
